Author Topic: AVR ATmega "PEN" and "SS" pins.  (Read 4494 times)
Offline SmAsHTopic starter
« on: January 02, 2010, 12:29:23 AM »
Hi, i was looking at the pinout for some atmegas today 64 and 32 and i noticed two pins that confused me.
PEN pin one on the mega64 has a description in pin definitions:
This is a programming enable pin for the SPI Serial Programming mode. By holding this pin low
during a Power-on Reset, the device will enter the SPI Serial Programming mode. PEN is internally
pulled high. The pullup is shown in Figure 22 on page 52 and its value is given in Section
“DC Characteristics” on page 325. PEN has no function during normal operation.
What exactly does this mean? That i have to hold it low to program the device?
Also, i found this on avr freaks but it didn't quite set it out for me:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=340086
The other pin that confused me was "SS", pin ten on the mega64.
It had no definition in the pin description area... I have read around and found it may have something to do with I2c?
Any help would be greatly appreciated.
« Last Edit: January 02, 2010, 12:34:03 AM by SmAsH »
Offline sonictj
  • Helpful? 11
Re: AVR ATmega "PEN" and "SS" pins.
« Reply #1 on: January 02, 2010, 02:59:16 AM »
pen is on a few of the older ATmegas and as the guys in avrfreaks said it serves much the same purpose as the reset line.  When low the PEN line drives the atmega into the a reset and holds until a power cycle occurs.  The SS function is for the spi interface.  I believe it stands for slave select, and I think it is an input used to enable the atmega's spi interface when in slave mode.  The master device uses the ss pin to turn on the atmega.  By having a slave select line multiple slaves can comunicate to one master.  This is assuming that the slaves tristate miso when ss is high (look in the spi portion of the datasheet).
« Reply #2 on: January 02, 2010, 03:11:03 AM »
So, is it safe to leave it disconnected? Or connect it to the programmer header?
Offline airman00
« Reply #3 on: January 02, 2010, 10:51:06 AM »
Treat it like the reset line and put a 10k pullup resistor
« Reply #4 on: January 02, 2010, 04:36:54 PM »
Ok, thanks airman00 :)
Last post November 28, 2006, 09:08:18 AM
Last post March 25, 2009, 12:12:53 AM
by pomprocker
Last post July 29, 2010, 05:30:10 AM
by blackbeard
Last post January 19, 2013, 10:05:19 PM
by jwatte
