Mechanics and Construction => Mechanics and Construction => Topic started by: mohamed on February 13, 2008, 06:46:45 AM
Title: can i use this servo in the 50$ robot?
Post by: mohamed on February 13, 2008, 06:46:45 AM
now i have Hitec HS-55 servo motor could i use this type instead fo the one mentioned in the tutorial or not?
waiting for your replies
thanks
Title: Re: can i use this servo in the 50$ robot?
Post by: cooldog on February 13, 2008, 06:51:04 AM
yes
Post by: gamefreak on February 13, 2008, 08:43:01 PM
All( or at least most) servos should work, as long as it has the same type of plug you are good, the biggest problem would be current draw.
Post by: Trumpkin on February 13, 2008, 08:46:59 PM
also it has to be 360 degree modifyable.
Post by: airman00 on February 13, 2008, 09:13:48 PM
almost all servos are EXCEPT those servos with output shafts that are metal ( since u can't shave off the stopper tab)
Post by: Trumpkin on February 14, 2008, 05:40:22 PM
micro servos are sometimes non-modifyable also. although i don't know why you would want to use micro servos.
