Software => Software => Topic started by: Adityav95 on December 26, 2010, 10:13:16 AM
Can anybody tell me how exactly to modify a Hitec HS-425BB servo using a ROBODUINO using arduino IDE? I have to modify the servo for continuous rotation.
Once u send the signal which is programmed, does the servo automatically center itself on connecting it to the roboduino with the battery or like do u have do some other action like pressing some button etc? I'm a total beginner, so pls bear with me.
Thnx
you have to send a pwm signal to the servo to centre it.
the pwm should have width of 1.5 ms to centre it.It depends on the serov ou are using
but i assume its the same for this servo.
look at this-------------->http://www.societyofrobots.com/actuators_servos.shtml (http://www.societyofrobots.com/actuators_servos.shtml)
and this---------------->http://arduino.cc/en/Tutorial/Sweep (http://arduino.cc/en/Tutorial/Sweep)
In the arduino IDE the command should be something like
servo servo1;
servo1.write(90);
thanks greasemonkey94! i was able to center my servo for modification :)
This was the exact code i used:
#include <Servo.h>
Servo servo1;
int pos = 0;
void setup()
{servo1.attach(9);}
void loop()
{servo1.write(90);
