Hey, I'm currently planning the construction of a tennisball pitching machine for my dad's dog. I was going to make the barrel by using some 4'' wide pvc pipe(i say wide because i'll be cutting it in half). On the back end will be a continuous rotation servo w/ a pushwheel attachment like on many soccerbots. this will push the tennisball into the spinning wheels when the ball hits the pressure sensor (1 wheel spins, the other is freely rotating to provide the ball stability).
Now, heres my dilemma. I've only ever used servos which only require a connection to the mcu. I know this is not the case with a brushless d/c motor, which is what i must use in order to launch tha ball properly. I know there are extras like and encoder, H-bridge, and motor controller needed in the assembly. from what i understand it goes-
MCU--> motor controller(w/ motor battery)--> H-bridge-->d/c motor
MCU------------------------------------------------------------>encoder---> D/C motor
I believe that this MCU should do the job w/ WinAVR-->(i need a cheap controller w/ some good features)
http://www.trossenrobotics.com/roboduino.aspx?a=blog (http://www.trossenrobotics.com/roboduino.aspx?a=blog)
and i figured this d/c motor should do the trick-->
i'll put up a googlesketch image soon
right now i'd just like some direction and to see what you fine, experienced engineers think.
THANK-YOU-THANK-YOU-THANK-YOU-THANK-YOU ;)
