Electronics => Electronics => Topic started by: szhang on October 22, 2008, 02:36:24 AM
I am still the in prototype process for my robot, and I haven't decided exactly on the hardware. So currently I have a 12V DC motor, and I got a 12V battery pack to power it. Though it might be possible for me to make the robot a bit smaller, and switching to a 6V motor, though I still have the 12V battery pack. So, what I am wondering is do you all think it would be a good idea (or just any reason not to?), in terms of power dissipation and stuff, to run motors with a 12V battery pack regulated to 6V.
This does have an advantage in that I can maintain a pretty consistent voltage to the motor (no voltage drop during high load). I found a pretty good switching regulator http://focus.ti.com/docs/prod/folders/print/ptn78020w.html (http://focus.ti.com/docs/prod/folders/print/ptn78020w.html) which has a listed efficiency of ~96% with a current out of 6A. I would need to redesign my motor driver, though that won't be too bad.
IMO, the battery pack that's meant to drive your motors should be built for the voltage of the motors - no regulation. Generally, the motors are the highest current draw on a wheeled robot, so don't waste money or battery energy regulating the motor voltage - just build (or buy) the correct battery pack.
You never want to regulate voltage to a motor:
http://www.societyofrobots.com/actuators_servos.shtml#regulate
Just buy a lower voltage battery - the weight savings will be an added bonus :D
Looking at the datasheet, your efficiency will be under 90%. That chip looks like a good find, although it's somewhat large at 1.5" x .9". . .
At 6V, it'll take less than 3A to hit the 90% mark, and I can see my combined current draw to be higher than 3A.
Normally I would agree not to regulate something like a motor, but I think I can afford the 10-20% energy loss (since I have double the energy capacity). Also, I really don't want the robot to slow down as the battery voltage drops, which is another reason I'd like a regulated power supply. The weight won't be a problem, size might be, so I still don't know about that.
I was surprised to see TI making that chip considering it is more a completely module with a PCB and everything. They even gave me a couple of samples (they are about $10-15 a pop otherwise). Though these things come with non-.1" spacing, which makes prototyping bit of a pain.
