Software => Software => Topic started by: Klinger on March 11, 2009, 06:10:37 AM
I my program I have a few While(1) statement but they are not staying in a infinite loop. I don't see any way they are break out of the statement
could you some reason why they are not staying in a infinite loop. Or other ways I can make a infinite loop I have tried for(;;) but that still did not work.
what is your setup? which microcontroller and which C compiler.
can you post an example of your code
Your compiler might not use while(1)... if you use gcc/winavr it should. Try while(1==1). That has the same purpose and should work no mater what.
??? what do you mean "not use while(1)" ? assuming we are talking about C, if your compiler does not loop for ever with this syntax then it's a bug in the compiler.
Your code should look like this:
while(1)
code here
you could also try
for(;;)
code here
Also make sure you don't have any interrupts running that somehow branch to a different part of your program.
Such as:
while(1){
//main loop
void example_function(void){
while(1){//do stuff
SIGNAL(interupt_vector){
example_function();
If you are using PICs make sure the watchdog timer is switched off
If you are using AVR, make sure you turn off optimization in the makefile. An empty while loop would otherwise be deleted when compiled (as it is useless).
Are you sure? Which compiler are you referring to? I just checked with gcc 3.2.3 on x86, with -O3 and -Os and as I would expect the while(1); loop was not removed.
I am very doubtful that any decent compiler would remove this statement, since this would change the execution flow of the program. A while(1); statement is NOT useless.
On the contraey, while(0); will probably be optimized out, since this is clearly useless.
Chelmi.
this is a bit more complex but it should work to as I see it:
code: //yes, I really want you to type "code"
//put your code here
goto code;
this should also be an infinite loop and should cancel out the chance of the compiler deleting the part of an infinite loop that makes it a infinite loop
goto code;
I know I sound repetitious, but no compiler will "delete the part of an infinite loop that makes it a infinite loop". I'm pretty sure his problem is not with the while(1) loop. Probably a bad interrupt handler or a watchdog timer, but without more info it's hard to tell.
I agree: the compiler wont get rid of a while(1){} but it would get rid of an empty for loop: eg for(int i=0; i<100;i++){} would get removed by optimisation.
Are you sure its jumping out of the loop - or is the microcontroller reseting and starting from the beginning again?
If it's an AVR chip, what are you doing inside this loop? make sure nothing touches your stack memory or else RET or RETI instructions will get confused (no out of bound array access and use free() for every malloc() and calloc()). Check the .lss file generated to see if the RJMP is correct and there's no possible path that can lead to the RJMP being skipped. If you can, run the code in the simulator. Also make sure your circuit is not noisy, a bad clock cycle might cause you to skip instructions.
No way, while(1) is never useless and compiler that doesn't know this is a weak compiler ;) there is no other way to stop the C written program to step over a part of memory outside its border
my bad ;D
