Software > Software
IrDA transceiver MCP2155
(1/1)
furkanhtk:
Hello, recently I bought IRDA proto board which has MCP2155. I tried communicating between two microcontrollers (raspberry and stm32) via Irda. After properly connecting the pins specified in the datasheet, I tried to connect by simply checking the status of the DSR, DTR, CTS, RTS pins. But the DSR pin never went to the 1 (high) state. In the MCP2155 datasheet, it is stated that the device works only as a secondary device. What I understood from this sentence was that 2 mcp2155 could not initiate communication between them mutually. But it was run without such an obligation in the video on the forum. I guess mcp2120 is used in the video but I'm not sure?
Do you have any ideas?, thank you for your help.
Best regards.
--- Quote ---Following are some images of my IrDA compatible transmitter. The first image is my schematic using the MCP2120 IC:
--- End quote ---
https://www.societyofrobots.com/electronics_irda_tutorial.shtml
https://www.mikroe.com/irda-proto-board
Navigation
