Electronics => Electronics => Topic started by: SmAsH on August 23, 2009, 12:09:22 AM
Does anyone know of a way to work out the capacitance of a smd ceramic capacitor?
I have a tonne of them sitting in a tray and would like to know if anyone has a way i could identify them.
Thanks in advance,
SmAsH
unfortunately it isn't simple :-\
I know only one way to find it out (as I know the only one)
You have to use multimeter able to measure capaticance (like this IMAGE (http://images.maplin.co.uk/full/gw26_sidenew.jpg)) and somehow connect it to your small capacitor (for example solder thin piceces of wire - taken from resistor - to soldering pads of capacitor)
to avoid situation like this - next time write on the tray value of capaticance (it should be done at the moment of buing - in the electronic shop)
damn, i guess im screwed for a while then...
my old fart of a multimeter doesn't measure capacitance :P
someday ill get a new one... someday...
thanks for that fiflak666 :)
youll need to make a cheet sheet when you measure them. i diddent even think of using them befor reading this post. heres some values i had laying around and what they measured out at...
# on cap -- Measured value
101 --- 100pf
10 --- 0.01pf
224 --- 220pf
475 ---- 47pf
Yes a good multimeter is worth its weight in gold. i have one such as the one pictured, as well as a desktop multimeter that has way too many functions... hope the values help, they should be accurate, i tested at least 2 of each value,(2 of the ones labled 475, 4 of the ones labled 101, 3 of the 10's and 5 of the 224's. written values are average not exact.
Truckstop
were those ones tantalum or ceramic?
i cant find any writing on my ceramic ones...
you won't find any writing because there are any :P
producent doesn't put any additional signs on smd capaticor because it would change its capacity
they are the rectangular surface mount caps. yes the smaller ones usually dont have writing on them but the larger ones do...
truckstop
There are several ways of measuring the capacitance.
Either use a capacitance bridge (cheap) or setup an oscillator (a 555 astable would do) with Cx as the frequency determining component and measure frequency - then calculate the value of Cx.
Calibrate either with caps of a known value.
