*   Copyright (c) 2008 www.societyofrobots.com
*   (please link back if you use this code!)
*   This program is free software; you can redistribute it and/or modify
*   it under the terms of the GNU General Public License version 2 as
*   published by the Free Software Foundation.
*   Alternatively, this software may be distributed under the terms of BSD
*   license.
//Add your code here
//enter your code in control here
//photovore is just a default sample program and can be deleted
void control(void)
	char cByte; 
	char dByte;
	char eByte;
	int modify_servo = 1;
	int sensitivity = 10;	//change this value to move servos in smaller increments.
	rprintfInit(uart1SendByte);
	delay_ms(50);
	rprintf("\nSELECT FROM THE FOLLOWING OPTIONS\n");
	rprintf("\n(o) LED on, \t\t(p) LED off");
	rprintf("\n(h)ome position, \t(w)alk forward, \t(s) walk reverse");
	rprintf("\n(m)odify servos");
	while(1)
		//rprintf("\n I'm in the first while loop\n");
		cByte=uart1GetByte(); //get byte from USB on the axon
		//rprintf("I got the cByte");
		if(cByte!=-1)//no new data
			//delay_ms(50);
			//rprintf("\n new data = %d \n", cByte);
			if (cByte == 'o')
				LED_on();
			if (cByte == 'p')
				LED_off();
			if (cByte == 'h')
				rprintf("\n I'm going to the home position\n");
				home_position();
			if (cByte == 'w')
				rprintf("\n I'm walking forward \n");
				walk_forward(100);//higher number slows gait down
			if (cByte == 's')
				rprintf("\n I'm walking reverse \n");
				walk_reverse(100);//higher number slows gait down
			if (cByte == 'm')
				rprintf("\nwhich servo would you like to move?\n");
				rprintf("0:left foot \t 1: right foot\n");
				rprintf("2:left ankle \t 3: right ankle\n");
				rprintf("4:left knee \t 5: right knee\n");
				rprintf("6:left thigh \t 7: right thigh\n");
				rprintf("8:left hip \t 9: right hip\n");
				rprintf("\n(p)rint all servo values to screen\n");
				rprintf("\n\nWARNING: Your robot will jolt into the home position \n");
				while(1)
					delay_ms(100);
					modify_servo = 1;
					cByte = uart1GetByte(); //get byte from USB on the axon;
					if(cByte != -1)//no new data
						modify_servo = 1;
//********************************begin of servo modifying********************************************
						if (cByte == '0')//left foot
							rprintf("+/- increment/decrement \t(d)one \n");
							while(modify_servo)
								cByte = uart1GetByte(); // get byte from USB on the axon
								if (cByte == '+')
									set_left_foot(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_left_foot(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									rprintf("\n Finished modifying current servo. Select another option\n");
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '1')//right foot
							while(modify_servo)
								if (cByte == '+')
									set_right_foot(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_right_foot(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									rprintf("\n Finished modifying current servo. Select anothe option\n");
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '2')//left ankle
							while(modify_servo)
								if (cByte == '+')
									set_left_ankle(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_left_ankle(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
								delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '3')//right ankle
							while(modify_servo)
								if (cByte == '+')
									set_right_ankle(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_right_ankle(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '4')//left knee
							while(modify_servo)
								if (cByte == '+')
									set_left_knee(sensitivity);
									delay_ms(10);
									biped_move();	
								if (cByte == '-')
									set_left_knee(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '5') //right knee
							while(modify_servo)
								if (cByte == '+')
									set_right_knee(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_right_knee(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '6')//left thigh
							while(modify_servo)
								if (cByte == '+')
									set_left_thigh(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_left_thigh(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '7')//right thigh
							while(modify_servo)
								if (cByte == '+')
									set_right_thigh(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_right_thigh(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '8')//left hip
							while(modify_servo)
								if (cByte == '+')
									set_left_hip(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_left_hip(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if (cByte == '9')//right hip
							while(modify_servo)
								if (cByte == '+')
									set_right_hip(sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == '-')
									set_right_hip(-sensitivity);
									delay_ms(10);
									biped_move();
								if (cByte == 'd')
									delay_ms(100);
									modify_servo = 0;
								delay_ms(100);
						if(cByte == 'p')
							print_servo_values();
							rprintf("\nselect another option\n");
//*******************************end of servo modifying************************************************
					delay_ms(300);
			delay_ms(300);
