# Makefile for ADABoot modified from ATmegaBOOT
# $Id$
# Brian B Riley  <brianbr@wulfden.org>  -- BBR
# 20090413: Modfified for ADAboot for 644P (BBR)
# 20090325: Modified for the ADABoot for 168 and 328 (BBR)
# 20050718: Created - E. Lins
# Instructions
#  make atmega168       - compile for 168
#  make atmega168_isp   - burn bootloader with ISP
#  make atmega328p      - compile for 328
#  make atmega328p_isp  - burn bootloader with ISP
#  (suggestions for 644 and 324p, but they are not implemented yet
#    need Fuse settings for 644 and 324p -- BBR
#  make atmega644p      - compile for 644p (alternately use 644 or 324p)
#  make atmega644p_isp  - burn bootloader with ISP (alternately use 644 or 324p)
# - if changes made only to Makefile, remember to "touch *.c"
#   to force make to recompile -- BBR
# program name should not be changed...
PROGRAM    = ATmegaBOOT
# enter the parameters for the avrdude isp tool
ISPTOOL	   = stk500v2
ISPPORT	   = usb
ISPSPEED   = -b 115200
MCU_TARGET = atmega168
LDSECTION  = --section-start=.text=0x3800
# the efuse should really be 0xf8; since, however, only the lower
# three bits of that byte are used on the atmega168, avrdude gets
# confused if you specify 1's for the higher bits, see:
# http://tinker.it/now/2007/02/24/the-tale-of-avrdude-atmega168-and-extended-bits-fuses/
# similarly, the lock bits should be 0xff instead of 0x3f (to
# unlock the bootloader section) and 0xcf instead of 0x0f (to
# lock it), but since the high two bits of the lock byte are
# unused, avrdude would get confused.
ISPFUSES    = avrdude -c $(ISPTOOL) -p $(MCU_TARGET) -P $(ISPPORT) $(ISPSPEED) \
-e -u -U lock:w:0x3f:m -U efuse:w:0x$(EFUSE):m -U hfuse:w:0x$(HFUSE):m -U lfuse:w:0x$(LFUSE):m
ISPFLASH    = avrdude -c $(ISPTOOL) -p $(MCU_TARGET) -P $(ISPPORT) $(ISPSPEED) \
-U flash:w:$(TARGET).hex -U lock:w:0x0f:m
STK500 = "C:\Program Files\Atmel\AVR Tools\STK500\Stk500.exe"
STK500-1 = $(STK500) -e -d$(MCU_TARGET) -pf -vf -if$(TARGET).hex \
-lFF -LFF -f$(HFUSE)$(LFUSE) -EF8 -ms -q -cUSB -I200kHz -s -wt
STK500-2 = $(STK500) -d$(MCU_TARGET) -ms -q -lCF -LCF -cUSB -I200kHz -s -wt
OBJ        = $(PROGRAM).o
OPTIMIZE   = -O2
DEFS       =
LIBS       =
CC         = avr-gcc
# Override is only needed by avr-lib build system.
override CFLAGS        = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) -DF_CPU=$(AVR_FREQ) $(DEFS)
override LDFLAGS       = -Wl,$(LDSECTION)
#override LDFLAGS       = -Wl,-Map,$(PROGRAM).map,$(LDSECTION)
OBJCOPY        = avr-objcopy
OBJDUMP        = avr-objdump
make: atmega640
atmega168: TARGET = atmega168
atmega168: MCU_TARGET = atmega168
atmega168: CFLAGS += '-DMAX_TIME_COUNT=F_CPU>>4' '-DADABOOT=4' '-DWATCHDOG_MODS'
atmega168: AVR_FREQ = 16000000L
atmega168: LDSECTION  = --section-start=.text=0x3800
atmega168: ADABoot_168.hex
atmega168_isp: atmega168
atmega168_isp: TARGET = ADABoot_168
atmega168_isp: MCU_TARGET = atmega168
atmega168_isp: HFUSE = DD
atmega168_isp: LFUSE = FF
atmega168_isp: EFUSE = 00
atmega168_isp: isp
atmega328p: TARGET = atmega328
atmega328p: MCU_TARGET = atmega328p
atmega328p: CFLAGS += '-DMAX_TIME_COUNT=F_CPU>>4' '-DBAUD_RATE=57600' '-DADABOOT=4' '-DWATCHDOG_MODS'
atmega328p: AVR_FREQ = 16000000L
atmega328p: LDSECTION  = --section-start=.text=0x7800
atmega328p: ADABoot_328.hex
atmega328p_isp: atmega328
atmega328p_isp: TARGET = ADABoot_328
atmega328p_isp: MCU_TARGET = atmega328p
atmega328p_isp: HFUSE = DA
atmega328p_isp: LFUSE = FF
atmega328p_isp: EFUSE = 05
atmega328p_isp: isp
atmega644p: TARGET = atmega644p
atmega644p: MCU_TARGET = atmega644p
atmega644p: CFLAGS += '-DMAX_TIME_COUNT=F_CPU>>4' '-DBAUD_RATE=38400' '-DADABOOT=4' '-DWATCHDOG_MODS'
atmega644p: AVR_FREQ = 16000000L
atmega644p: LDSECTION  = --section-start=.text=0xF000
atmega644p: ADABoot_644p.hex
atmega644p_isp: atmega644p
atmega644p_isp: TARGET = ADABoot_644p
atmega644p_isp: MCU_TARGET = atmega644p
atmega644p_isp: HFUSE = DC
atmega644p_isp: LFUSE = FF
atmega644p_isp: EFUSE = FD
atmega644p_isp: isp
atmega640: TARGET = atmega640
atmega640: MCU_TARGET = atmega640
atmega640: CFLAGS += '-DMAX_TIME_COUNT=F_CPU>>4' '-DBAUD_RATE=57600' '-DADABOOT=4' '-DWATCHDOG_MODS'
atmega640: AVR_FREQ = 16000000L
atmega640: LDSECTION  = --section-start=.text=0xF000
atmega640: ADABoot_640.hex
atmega640_isp: atmega640
atmega640_isp: TARGET = ADABoot_640
atmega640_isp: MCU_TARGET = atmega640
atmega640_isp: HFUSE = DA
atmega640_isp: LFUSE = FF
atmega640_isp: EFUSE = F5
atmega640_isp: isp
isp: $(TARGET)
	$(ISPFUSES)
	$(ISPFLASH)
isp-stk500: $(TARGET).hex
	$(STK500-1)
	$(STK500-2)
%.elf: $(OBJ)
	$(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS)
clean:
	rm -rf *.o *.elf *.lst *.map *.sym *.lss *.eep *.srec *.bin *.hex
%.lst: %.elf
	$(OBJDUMP) -h -S $< > $@
%.hex: %.elf
	$(OBJCOPY) -j .text -j .data -O ihex $< $@
%.srec: %.elf
	$(OBJCOPY) -j .text -j .data -O srec $< $@
%.bin: %.elf
	$(OBJCOPY) -j .text -j .data -O binary $< $@
