<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="7" fill="1" visible="yes" active="yes"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="gm-diodes">
<description>&lt;b&gt;Diodes&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;Zener 1N47xx (as in protection for the MOSFET in the AMZ MOSFET Booster)
&lt;li&gt;rectifier 1N4001-1N4008 (for polarity reversal protection in power supply sections)
&lt;li&gt;clipping 1N914 (as in a TS808)
&lt;li&gt;LED (light emitting diode, 3mm and 5mm)
&lt;li&gt;mostly gathered from Eagle libraries
&lt;/ul&gt;</description>
<packages>
<package name="DO35-2">
<description>&lt;b&gt;DO-35 0.2" pad spacing&lt;/b&gt;</description>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-2.4638" y2="0" width="0.508" layer="21"/>
<wire x1="2.54" y1="0" x2="2.4638" y2="0" width="0.508" layer="21"/>
<pad name="C" x="-2.54" y="0" drill="0.9" shape="square"/>
<pad name="A" x="2.54" y="0" drill="0.9"/>
<text x="-1.2954" y="-0.635" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
</package>
<package name="LED5MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205" cap="flat"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.9"/>
<pad name="K" x="1.27" y="0" drill="0.9" shape="square"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="DO35-3">
<description>&lt;B&gt;DO-35 0.3" spacing&lt;/B&gt;</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<pad name="C" x="-3.81" y="0" drill="0.9" shape="square"/>
<pad name="A" x="3.81" y="0" drill="0.9"/>
<text x="-1.27" y="-0.635" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO35-4">
<description>&lt;B&gt;DO-35 0.4" spacing&lt;/B&gt;</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.9" diameter="1.4224" shape="square"/>
<pad name="A" x="5.08" y="0" drill="0.9" diameter="1.4224"/>
<text x="-1.3716" y="-0.635" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="LED3MM">
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361" cap="flat"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208" cap="flat"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165" cap="flat"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361" cap="flat"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337" cap="flat"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102" cap="flat"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876" cap="flat"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876" cap="flat"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108" cap="flat"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949" cap="flat"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022" cap="flat"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822" cap="flat"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="LED">
<wire x1="2.54" y1="-1.27" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="2.54" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.27" x2="2.54" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.778" y1="2.032" x2="0.381" y2="3.429" width="0.1524" layer="94"/>
<wire x1="0.635" y1="1.905" x2="-0.762" y2="3.302" width="0.1524" layer="94"/>
<text x="-2.032" y="-3.556" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.032" y="-5.715" size="1.778" layer="96">&gt;VALUE</text>
<pin name="C" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="A" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<polygon width="0.1524" layer="94">
<vertex x="0.381" y="3.429"/>
<vertex x="1.27" y="3.048"/>
<vertex x="0.762" y="2.54"/>
</polygon>
<vertex x="-0.762" y="3.302"/>
<vertex x="0.127" y="2.921"/>
<vertex x="-0.381" y="2.413"/>
</polygon>
</symbol>
<symbol name="D">
<wire x1="-2.54" y1="-1.27" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-2.54" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-1.27" width="0.254" layer="94"/>
<text x="-3.556" y="2.0066" size="1.778" layer="95" font="vector">&gt;NAME</text>
<text x="-4.318" y="-3.5814" size="1.778" layer="96" font="vector">&gt;VALUE</text>
<pin name="A" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="ZD">
<wire x1="0" y1="-1.27" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.27" x2="1.905" y2="-1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="1.27" x2="3.1115" y2="1.27" width="0.254" layer="94"/>
<text x="-1.778" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.778" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LED" prefix="D">
<gates>
<gate name="G$1" symbol="LED" x="0" y="2.54"/>
</gates>
<devices>
<device name="3MM" package="LED3MM">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="K"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="5MM" package="LED5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N914" prefix="D">
<description>&lt;b&gt;Fast Switching Diode&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;DO-35 glass case
&lt;li&gt;a.k.a. 1N4148
<gates>
<gate name="G$1" symbol="D" x="-1.27" y="0"/>
</gates>
<devices>
<device name=".2" package="DO35-2">
<connects>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
<device name=".3" package="DO35-3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name=".4" package="DO35-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N9*ZENER" prefix="D" uservalue="yes">
<description>&lt;b&gt;1N9???B Zener Diode&lt;/b&gt;&lt;br&gt;
&lt;ul&gt;
&lt;li&gt;DO-35 case&lt;/li&gt;
&lt;li&gt;1N957B - 1N992B (6.8V to 200V)
<gates>
<gate name="G$1" symbol="ZD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DO35-3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2" package="DO35-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="4" package="DO35-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="gm-supply">
<description>&lt;b&gt;Supply&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;input, output, ground, and power supply.
&lt;li&gt;these are used on a schematic for placeholders and on a board for pads for off-board components like jacks.
<packages>
<package name="AB9V">
<description>&lt;B&gt;9-V BATTERY CLIP&lt;/B&gt;</description>
<wire x1="-2.54" y1="-3.175" x2="-2.54" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-2.54" y1="4.318" x2="-1.778" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="5.08" x2="1.778" y2="5.08" width="0.1524" layer="21"/>
<wire x1="2.54" y1="4.318" x2="1.778" y2="5.08" width="0.1524" layer="21"/>
<wire x1="2.54" y1="4.318" x2="2.54" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-5.08" x2="2.54" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-5.08" x2="-1.778" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-4.318" x2="-1.778" y2="-5.08" width="0.1524" layer="21"/>
<circle x="0" y="2.54" radius="1.27" width="0.1524" layer="51"/>
<circle x="0" y="-2.54" radius="1.27" width="0.1524" layer="51"/>
<pad name="-" x="0" y="-2.54" drill="1.1176" diameter="3.1496" shape="octagon"/>
<pad name="+" x="0" y="2.54" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-1.905" y="-1.143" size="1.27" layer="21" ratio="16" rot="R90">9V</text>
<text x="-3.81" y="-2.54" size="1.27" layer="25" ratio="12" rot="R90">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="GND">
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<text x="-1.905" y="-3.175" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="BATTERY">
<wire x1="-1.143" y1="-1.905" x2="1.143" y2="-1.905" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="-0.635" x2="2.54" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="1.905" x2="2.54" y2="1.905" width="0.4064" layer="94"/>
<wire x1="-1.143" y1="0.635" x2="1.143" y2="0.635" width="0.4064" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.778" width="0.127" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.127" layer="94"/>
<text x="4.445" y="0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="4.445" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="2.413" size="1.524" layer="94">+</text>
<text x="-1.905" y="-3.937" size="1.524" layer="94">-</text>
<pin name="+" x="0" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="-" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" prefix="GND">
<description>&lt;b&gt;Ground&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;use this to hook up ground connections throughout a schematic instead of running wire&lt;/li&gt;
&lt;li&gt;automatically labels the net "GND"&lt;/li&gt;
<gates>
<gate name="GND" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="9VBATTERY" prefix="V">
<gates>
<gate name="G$1" symbol="BATTERY" x="0" y="0"/>
</gates>
<devices>
<device name="" package="AB9V">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="gm-trans">
<description>&lt;b&gt;Transistors&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;small signal amps (e.g., 2N508x)
&lt;li&gt;switching transistors (e.g., 2N2222, 2N390x)
&lt;li&gt;JFETs (e.g., J201, 2N3819, 2N5457)
&lt;li&gt;MOSFETs (e.g., BS170, BS250)
&lt;li&gt;mostly copied from Eagle libraries
<packages>
<package name="SOT54E">
<description>&lt;b&gt;SOT-54&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="-0.9692" y1="2.2098" x2="0.9692" y2="2.2098" width="0.1524" layer="51" curve="-47.363718" cap="flat"/>
<wire x1="-1.631" y1="-1.778" x2="-0.9689" y2="2.2098" width="0.1524" layer="21" curve="-113.782137" cap="flat"/>
<wire x1="0.9689" y1="2.2098" x2="1.631" y2="-1.778" width="0.1524" layer="21" curve="-113.782137" cap="flat"/>
<wire x1="-1.631" y1="-1.778" x2="1.631" y2="-1.778" width="0.1524" layer="21"/>
<pad name="D" x="-1.27" y="0" drill="0.7" shape="octagon"/>
<pad name="G" x="0" y="1.905" drill="0.7" shape="octagon"/>
<pad name="S" x="1.27" y="0" drill="0.7" shape="octagon"/>
<text x="3.175" y="-1.905" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<text x="3.175" y="0" size="1.27" layer="25" ratio="12">&gt;NAME</text>
</package>
<package name="SOT54ES">
<pad name="D" x="-2.54" y="0" drill="0.7" shape="octagon"/>
<pad name="G" x="0" y="0" drill="0.7" shape="octagon"/>
<pad name="S" x="2.54" y="0" drill="0.7" shape="octagon"/>
<text x="-2.159" y="-3.175" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<text x="-1.397" y="-1.524" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.921" y="0.889" size="0.6096" layer="21">D</text>
<text x="2.286" y="0.889" size="0.6096" layer="21">S</text>
</package>
<package name="TO92-">
<wire x1="-2.54" y1="0" x2="-1.778" y2="0" width="0.508" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="0.254" width="0.508" layer="21"/>
<wire x1="2.54" y1="0" x2="1.778" y2="0" width="0.508" layer="21"/>
<pad name="3" x="-2.54" y="0" drill="0.7" shape="octagon"/>
<pad name="2" x="0" y="0" drill="0.7" shape="octagon"/>
<pad name="1" x="2.54" y="0" drill="0.7" shape="octagon"/>
</package>
</packages>
<symbols>
<symbol name="IGFNA">
<wire x1="-1.1176" y1="2.413" x2="-1.1176" y2="0" width="0.254" layer="94"/>
<wire x1="2.54" y1="1.905" x2="0.5334" y2="1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0.508" y1="0" x2="1.778" y2="0.381" width="0.1524" layer="94"/>
<wire x1="1.778" y1="0.381" x2="1.778" y2="-0.381" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-0.381" x2="0.508" y2="0" width="0.1524" layer="94"/>
<wire x1="0.508" y1="0" x2="1.143" y2="0" width="0.1524" layer="94"/>
<wire x1="1.143" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="0.508" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-1.1176" y1="0" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="-1.1176" y1="0" x2="-1.1176" y2="-2.54" width="0.254" layer="94"/>
<wire x1="1.651" y1="0.127" x2="1.143" y2="0" width="0.3048" layer="94"/>
<wire x1="1.143" y1="0" x2="1.651" y2="-0.127" width="0.3048" layer="94"/>
<circle x="2.54" y="-1.905" radius="0.254" width="0.4064" layer="94"/>
<text x="5.08" y="0" size="1.778" layer="95">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="2.413" size="0.8128" layer="93">D</text>
<text x="1.143" y="-3.175" size="0.8128" layer="93">S</text>
<text x="-2.413" y="0.381" size="0.8128" layer="93">G</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="-1.27" layer="94"/>
<rectangle x1="-0.254" y1="1.27" x2="0.508" y2="2.54" layer="94"/>
<rectangle x1="-0.254" y1="-0.889" x2="0.508" y2="0.889" layer="94"/>
<pin name="G" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="D" x="2.54" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="S" x="2.54" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="NPN-1">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BS170" prefix="Q">
<description>&lt;b&gt;N-CHANNEL MOS FET&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="IGFNA" x="0" y="0"/>
</gates>
<devices>
<device name="T" package="SOT54E">
<connects>
<connect gate="1" pin="D" pad="D"/>
<connect gate="1" pin="G" pad="G"/>
<connect gate="1" pin="S" pad="S"/>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="SOT54ES">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BC550" prefix="Q">
<gates>
<gate name="G$1" symbol="NPN-1" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="TO92-">
<connects>
<connect gate="G$1" pin="B" pad="2"/>
<connect gate="G$1" pin="C" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="gm-resistors">
<description>&lt;b&gt;Resistors&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;6mm long -- the size of 1/4 watt resistors
&lt;li&gt; all resistor values have the same size package; you choose the value of resistance
<packages>
<package name="R0207/1V">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;br&gt;
&lt;br&gt;
vertical position&lt;br&gt;
format: 0.1" (perfboard)&lt;br&gt;
spacing: 1 hole
&lt;p&gt;This length resistor applies to 1/4 watt metal film.</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.6096" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.7"/>
<pad name="2" x="1.27" y="0" drill="0.7"/>
<text x="-0.6096" y="0.6604" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.3716" y="-2.1844" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="R0207/2V">
&lt;br&gt;
vertical placement&lt;br&gt;
spacing: 2 holes
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<wire x1="-1.397" y1="0" x2="-0.508" y2="0" width="0.508" layer="21"/>
<circle x="-2.54" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-2.54" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.7"/>
<pad name="2" x="2.54" y="0" drill="0.7"/>
<text x="-1.6256" y="0.4064" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.8796" y="-1.5494" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="R0207/3">
&lt;br&gt;
length: 6mm&lt;br&gt;
spacing: 3 holes
<wire x1="3.81" y1="0" x2="3.0386" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.81" y1="0" x2="-3.0386" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.81" y1="0.762" x2="-2.556" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.81" y1="-0.762" x2="-2.556" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.556" y1="-1.016" x2="2.81" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.556" y1="1.016" x2="2.81" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.81" y1="-0.762" x2="-2.81" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.556" y1="1.016" x2="-1.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.413" y1="0.889" x2="-1.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.556" y1="-1.016" x2="-1.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.413" y1="-0.889" x2="-1.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.413" y1="0.889" x2="1.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.413" y1="0.889" x2="-1.413" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.413" y1="-0.889" x2="1.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.413" y1="-0.889" x2="-1.413" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.556" y1="1.016" x2="1.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.556" y1="-1.016" x2="1.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.81" y1="-0.762" x2="2.81" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.7"/>
<pad name="2" x="3.81" y="0" drill="0.7"/>
<text x="-1.27" y="-0.635" size="1.27" layer="25" font="vector" ratio="12">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27" font="vector" ratio="12">&gt;VALUE</text>
</package>
<package name="R0207/4">
&lt;br&gt;
spacing: 4 holes
<wire x1="5.08" y1="0" x2="3.0386" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.0386" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="0.7"/>
<pad name="2" x="5.08" y="0" drill="0.7"/>
<text x="-1.2606" y="-2.5146" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="2.81" y1="-0.254" x2="3.191" y2="0.254" layer="21"/>
<rectangle x1="-3.191" y1="-0.254" x2="-2.81" y2="0.254" layer="21"/>
</package>
<package name="R0207/5">
&lt;br&gt;
spacing: 5 holes
<wire x1="6.35" y1="0" x2="3.0386" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-3.0386" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="0.7"/>
<pad name="2" x="6.35" y="0" drill="0.7"/>
<text x="-1.27" y="-0.6096" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.2606" y="-2.2606" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="R0207/6">
&lt;br&gt;
spacing: 6 holes
<wire x1="7.62" y1="0" x2="3.0386" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-3.0386" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.7"/>
<pad name="2" x="7.62" y="0" drill="0.7"/>
</package>
<package name="R0207/4A">
&lt;br&gt;
spacing: 4 holes (with body offset)
</package>
</packages>
<symbols>
<symbol name="R-US">
<wire x1="-2.54" y1="0" x2="-2.159" y2="1.016" width="0.2032" layer="94"/>
<wire x1="-2.159" y1="1.016" x2="-1.524" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="-1.524" y1="-1.016" x2="-0.889" y2="1.016" width="0.2032" layer="94"/>
<wire x1="-0.889" y1="1.016" x2="-0.254" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="-0.254" y1="-1.016" x2="0.381" y2="1.016" width="0.2032" layer="94"/>
<wire x1="0.381" y1="1.016" x2="1.016" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="1.016" y1="-1.016" x2="1.651" y2="1.016" width="0.2032" layer="94"/>
<wire x1="1.651" y1="1.016" x2="2.286" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="0" width="0.2032" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="6MM" prefix="R" uservalue="yes">
<description>&lt;b&gt;6mm Resistors&lt;/b&gt;
&lt;p&gt;Leads spaced 1-6 holes apart for 0.1" perfboard. Suitable for 1/4 watt resistors.&lt;/p&gt;</description>
<gates>
<gate name="G$1" symbol="R-US" x="0" y="0"/>
</gates>
<devices>
<device name=".1" package="R0207/1V">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name=".2" package="R0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name=".3" package="R0207/3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name=".4" package="R0207/4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name=".5" package="R0207/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name=".6" package="R0207/6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name=".4.1" package="R0207/4A">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="gm-caps-electro-pol">
<description>&lt;b&gt;Capacitors, Polar Electrolytic, Radial &lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;large value capacitors: .22 - 470uF (uF = µF = mF)
&lt;li&gt;often used in power supply filters
<packages>
<package name="050_020">
<description>&lt;b&gt;5mm diameter, 2mm lead spacing&lt;/b&gt;</description>
<wire x1="-1.143" y1="1.6764" x2="-1.143" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="1.3716" x2="-1.4732" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-1" y1="0" x2="-1.05" y2="0" width="0.6096" layer="51"/>
<wire x1="1" y1="0" x2="1.05" y2="0" width="0.6096" layer="51"/>
<circle x="0" y="0" radius="2.5" width="0.1524" layer="21"/>
<pad name="+" x="-1" y="0" drill="0.7" shape="square"/>
<pad name="-" x="1" y="0" drill="0.7"/>
<text x="-1.143" y="-2.032" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.27" y="-3.937" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="050_020_1">
<description>&lt;b&gt;5mm diameter, 2mm lead spacing, 0.1" pad spacing&lt;/b&gt;</description>
<wire x1="-1" y1="0" x2="-1.25" y2="0" width="0.6096" layer="51"/>
<wire x1="1" y1="0" x2="1.25" y2="0" width="0.6096" layer="51"/>
<pad name="+" x="-1.27" y="0" drill="0.7" shape="square"/>
<pad name="-" x="1.27" y="0" drill="0.7"/>
<text x="-1.27" y="-2.032" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.27" y="-3.81" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="050_020_2">
<description>&lt;b&gt;5mm diameter, 2mm lead spacing, 0.2" pad spacing&lt;/b&gt;</description>
<wire x1="-3.048" y1="1.6764" x2="-3.048" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-2.7178" y1="1.3716" x2="-3.3782" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-2.27" y1="0" x2="-2.52" y2="0" width="0.6096" layer="51"/>
<wire x1="2.27" y1="0" x2="2.52" y2="0" width="0.6096" layer="51"/>
<pad name="+" x="-2.54" y="0" drill="0.7" shape="square"/>
<pad name="-" x="2.54" y="0" drill="0.7"/>
<text x="-1.524" y="-0.635" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.651" y="-3.81" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="050_020_3">
<description>&lt;b&gt;5mm diameter, 2mm lead spacing, 0.3" pad spacing&lt;/b&gt;</description>
<wire x1="-3.683" y1="1.6764" x2="-3.683" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="1.3716" x2="-4.0132" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-2.27" y1="0" x2="-3.79" y2="0" width="0.6096" layer="51"/>
<wire x1="2.27" y1="0" x2="3.79" y2="0" width="0.6096" layer="51"/>
<pad name="+" x="-3.81" y="0" drill="0.7" shape="square"/>
<pad name="-" x="3.81" y="0" drill="0.7"/>
<text x="-1.778" y="-0.635" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.397" y="-3.937" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="050_020_4">
<description>&lt;b&gt;5mm diameter, 2mm lead spacing, 0.4" pad spacing&lt;/b&gt;</description>
<wire x1="-4.953" y1="1.6764" x2="-4.953" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-4.6228" y1="1.3716" x2="-5.2832" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-2.27" y1="0" x2="-5.06" y2="0" width="0.6096" layer="51"/>
<wire x1="2.27" y1="0" x2="5.06" y2="0" width="0.6096" layer="51"/>
<pad name="+" x="-5.08" y="0" drill="0.7" shape="square"/>
<pad name="-" x="5.08" y="0" drill="0.7"/>
<text x="-1.524" y="-3.937" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="CPOL-EU">
<wire x1="0" y1="0" x2="0" y2="0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="2.032" width="0.1524" layer="94"/>
<wire x1="-2.0574" y1="1.524" x2="2.0574" y2="1.524" width="0.1524" layer="94"/>
<wire x1="2.0574" y1="1.524" x2="2.0574" y2="2.032" width="0.1524" layer="94"/>
<wire x1="2.0574" y1="2.032" x2="0" y2="2.032" width="0.1524" layer="94"/>
<wire x1="0" y1="2.032" x2="-2.0574" y2="2.032" width="0.1524" layer="94"/>
<wire x1="-2.0574" y1="2.032" x2="-2.0574" y2="1.524" width="0.1524" layer="94"/>
<text x="1.524" y="2.921" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-2.159" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="2.54" size="1.27" layer="94">+</text>
<rectangle x1="-2.032" y1="0.508" x2="2.032" y2="1.016" layer="94"/>
<pin name="-" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="050-EU" prefix="C" uservalue="yes">
<gates>
<gate name="G$1" symbol="CPOL-EU" x="0" y="-2.54"/>
</gates>
<devices>
<device name="" package="050_020">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1" package="050_020_1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2" package="050_020_2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3" package="050_020_3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="4" package="050_020_4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="ic-package">
<description>&lt;b&gt;IC Packages an Sockets&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL18">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="11.43" y1="2.921" x2="-11.43" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.016" x2="-11.43" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.684" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.525" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOCKET-18">
<description>&lt;b&gt;Dual In Line Socket&lt;/b&gt;</description>
<wire x1="11.43" y1="5.08" x2="-11.43" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.08" x2="11.43" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="11.43" y1="5.08" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.08" x2="-11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.08" x2="-11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.54" x2="11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.54" x2="11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.54" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-2.54" x2="11.43" y2="-5.08" width="0.1524" layer="21"/>
<text x="-8.255" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-11.684" y="-4.953" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="DIL18">
<wire x1="-5.08" y1="11.43" x2="-5.08" y2="-11.43" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-11.43" x2="5.08" y2="-11.43" width="0.254" layer="94"/>
<wire x1="5.08" y1="-11.43" x2="5.08" y2="11.43" width="0.254" layer="94"/>
<wire x1="5.08" y1="11.43" x2="2.54" y2="11.43" width="0.254" layer="94"/>
<wire x1="-5.08" y1="11.43" x2="-2.54" y2="11.43" width="0.254" layer="94"/>
<wire x1="-2.54" y1="11.43" x2="2.54" y2="11.43" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="12.065" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-13.97" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DIL18" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line / Socket&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="DIL18" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL18">
<connects>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="17" pad="17"/>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="gm-switches">
<description>&lt;b&gt;Switches&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;SPST, SPDT, DPDT, 3PDT
<packages>
<package name="SPST">
<pad name="2" x="1.27" y="0" drill="0.7" shape="square"/>
<pad name="1" x="-1.27" y="0" drill="0.7" shape="square"/>
<text x="-2.54" y="1.27" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.54" y="-1.27" size="0.8128" layer="21" ratio="12">1</text>
<text x="1.905" y="-1.27" size="0.8128" layer="21" ratio="12">2</text>
</package>
</packages>
<symbols>
<symbol name="SPST">
<wire x1="0" y1="-3.175" x2="0" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-1.905" x2="-2.413" y2="2.413" width="0.254" layer="94"/>
<circle x="0" y="2.54" radius="0.762" width="0.4064" layer="94"/>
<text x="3.81" y="-4.445" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<pin name="P" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="S" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="SPST" prefix="SW">
<gates>
<gate name="G$1" symbol="SPST" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SPST">
<connects>
<connect gate="G$1" pin="P" pad="1"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="ZN5">
<description>&lt;b&gt;Miniature Power PCB Relay&lt;/b&gt; SCHRACK&lt;p&gt;
1pole 10 A&lt;br&gt;
Source: http://www.schrack.com/.. 5847.pdf</description>
<wire x1="-11.46" y1="8.15" x2="10.84" y2="8.15" width="0.2032" layer="21"/>
<wire x1="10.84" y1="8.15" x2="10.84" y2="-8.15" width="0.2032" layer="21"/>
<wire x1="10.84" y1="-8.15" x2="-11.46" y2="-8.15" width="0.2032" layer="21"/>
<wire x1="-11.46" y1="-8.15" x2="-11.46" y2="8.15" width="0.2032" layer="21"/>
<pad name="11" x="8.89" y="0" drill="1.3" diameter="2.5" rot="R180"/>
<pad name="A1" x="6.89" y="6" drill="1.3" diameter="2.5" rot="R180"/>
<pad name="A2" x="6.89" y="-6" drill="1.3" diameter="2.5" rot="R180"/>
<pad name="12" x="-5.31" y="-6.2" drill="1.3" diameter="2.5" rot="R180"/>
<pad name="14" x="-5.31" y="6" drill="1.3" diameter="2.5" rot="R180"/>
<text x="-8.89" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.89" y="-1.27" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="K">
<wire x1="-3.81" y1="-1.905" x2="-1.905" y2="-1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.905" x2="1.905" y2="1.905" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.905" x2="3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="1.905" x2="-3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="1.905" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="0" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.905" x2="0" y2="1.905" width="0.254" layer="94"/>
<text x="1.27" y="2.921" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="5.08" size="1.778" layer="95">&gt;PART</text>
<pin name="2" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="1" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="U">
<wire x1="3.175" y1="5.08" x2="1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="-3.175" y1="5.08" x2="-1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="2.54" y2="5.715" width="0.254" layer="94"/>
<circle x="0" y="1.27" radius="0.127" width="0.4064" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="95">&gt;PART</text>
<pin name="O" x="5.08" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="S" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="P" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ZNS5*" prefix="K">
<gates>
<gate name="1" symbol="K" x="-7.62" y="0" addlevel="must"/>
<gate name="2" symbol="U" x="10.16" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="ZN5">
<connects>
<connect gate="1" pin="1" pad="A1"/>
<connect gate="1" pin="2" pad="A2"/>
<connect gate="2" pin="O" pad="12"/>
<connect gate="2" pin="P" pad="11"/>
<connect gate="2" pin="S" pad="14"/>
</connects>
<technologies>
<technology name="106">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
<technology name="112">
</technology>
<technology name="124">
</technology>
<technology name="136">
</technology>
<technology name="148">
</technology>
<technology name="406">
</technology>
<technology name="412">
</technology>
<technology name="424">
</technology>
<technology name="436">
</technology>
<technology name="448">
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="Q2" library="gm-trans" deviceset="BS170" device=""/>
<part name="R2" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="C4" library="gm-caps-electro-pol" deviceset="050-EU" device="1"/>
<part name="GND4" library="gm-supply" deviceset="GND" device=""/>
<part name="D4" library="gm-diodes" deviceset="1N914" device=".3"/>
<part name="IC4" library="ic-package" deviceset="DIL18" device=""/>
<part name="GND12" library="gm-supply" deviceset="GND" device=""/>
<part name="D16" library="gm-diodes" deviceset="LED" device="5MM"/>
<part name="R7" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="R8" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="GND13" library="gm-supply" deviceset="GND" device=""/>
<part name="Q5" library="gm-trans" deviceset="BS170" device=""/>
<part name="R9" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="C11" library="gm-caps-electro-pol" deviceset="050-EU" device="1"/>
<part name="GND14" library="gm-supply" deviceset="GND" device=""/>
<part name="D17" library="gm-diodes" deviceset="1N914" device=".3"/>
<part name="Q6" library="gm-trans" deviceset="BS170" device=""/>
<part name="R10" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="C12" library="gm-caps-electro-pol" deviceset="050-EU" device="1"/>
<part name="GND15" library="gm-supply" deviceset="GND" device=""/>
<part name="D18" library="gm-diodes" deviceset="1N914" device=".3"/>
<part name="Q7" library="gm-trans" deviceset="BS170" device=""/>
<part name="R11" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="C13" library="gm-caps-electro-pol" deviceset="050-EU" device="1"/>
<part name="GND16" library="gm-supply" deviceset="GND" device=""/>
<part name="D19" library="gm-diodes" deviceset="1N914" device=".3"/>
<part name="T1" library="gm-trans" deviceset="BC550" device=""/>
<part name="R1" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="SW1" library="gm-switches" deviceset="SPST" device=""/>
<part name="D1" library="gm-diodes" deviceset="1N9*ZENER" device=""/>
<part name="GND1" library="gm-supply" deviceset="GND" device=""/>
<part name="V10" library="gm-supply" deviceset="9VBATTERY" device=""/>
<part name="GND2" library="gm-supply" deviceset="GND" device=""/>
<part name="D2" library="gm-diodes" deviceset="1N914" device=".3"/>
<part name="D3" library="gm-diodes" deviceset="1N914" device=".3"/>
<part name="V1" library="gm-supply" deviceset="9VBATTERY" device=""/>
<part name="V2" library="gm-supply" deviceset="9VBATTERY" device=""/>
<part name="V3" library="gm-supply" deviceset="9VBATTERY" device=""/>
<part name="V4" library="gm-supply" deviceset="9VBATTERY" device=""/>
<part name="T2" library="gm-trans" deviceset="BC550" device=""/>
<part name="K1" library="relay" deviceset="ZNS5*" device="" technology="436"/>
<part name="GND3" library="gm-supply" deviceset="GND" device=""/>
<part name="R3" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="R4" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="T3" library="gm-trans" deviceset="BC550" device=""/>
<part name="R5" library="gm-resistors" deviceset="6MM" device=".3"/>
<part name="D5" library="gm-diodes" deviceset="1N9*ZENER" device=""/>
<part name="GND5" library="gm-supply" deviceset="GND" device=""/>
</parts>
<sheets>
<sheet>
<plain>
<text x="787.4" y="20.32" size="1.778" layer="91">12V</text>
<text x="403.86" y="175.26" size="1.778" layer="91">data in</text>
<text x="693.42" y="86.36" size="1.778" layer="91">12V</text>
<text x="698.5" y="-58.42" size="1.778" layer="91">12V</text>
<text x="601.98" y="20.32" size="1.778" layer="91">12V</text>
<text x="370.84" y="172.72" size="1.778" layer="91">5v vcc</text>
<text x="381" y="144.78" size="1.778" layer="91">led</text>
<text x="401.32" y="213.36" size="1.778" layer="91">http://www9.dw-world.de/rtc/infotheque/semiconamps/semiconductor_amps5.html</text>
<text x="345.44" y="195.58" size="1.778" layer="91">to rf receiver</text>
<text x="701.04" y="60.96" size="6.4516" layer="91">IRF640</text>
<text x="805.18" y="-7.62" size="6.4516" layer="91">IRF640</text>
<text x="728.98" y="-88.9" size="6.4516" layer="91">IRF640</text>
<text x="629.92" y="2.54" size="6.4516" layer="91">IRF640</text>
<text x="383.54" y="203.2" size="1.778" layer="91">homemade darlington pair for better regulation</text>
<text x="703.58" y="50.8" size="1.778" layer="91">Low Esr</text>
<text x="795.02" y="-15.24" size="1.778" layer="91">Low Esr</text>
<text x="706.12" y="-96.52" size="1.778" layer="91">Low Esr</text>
<text x="609.6" y="-15.24" size="1.778" layer="91">Low Esr</text>
<text x="601.98" y="43.18" size="1.778" layer="91">trigger</text>
<text x="568.96" y="50.8" size="1.778" layer="91">trigger</text>
<text x="533.4" y="50.8" size="1.778" layer="91">trigger</text>
<text x="546.1" y="53.34" size="1.778" layer="91">7.2v</text>
</plain>
<instances>
<instance part="Q2" gate="1" x="779.78" y="-15.24"/>
<instance part="R2" gate="G$1" x="772.16" y="-10.16" rot="R90"/>
<instance part="C4" gate="G$1" x="792.48" y="-15.24"/>
<instance part="GND4" gate="GND" x="784.86" y="-25.4"/>
<instance part="D4" gate="G$1" x="777.24" y="2.54" rot="R90"/>
<instance part="IC4" gate="G$1" x="391.16" y="129.54" rot="R90"/>
<instance part="GND12" gate="GND" x="401.32" y="96.52"/>
<instance part="D16" gate="G$1" x="383.54" y="144.78" rot="R270"/>
<instance part="R7" gate="G$1" x="383.54" y="152.4" rot="R270"/>
<instance part="R8" gate="G$1" x="386.08" y="152.4" rot="R270"/>
<instance part="GND13" gate="GND" x="383.54" y="162.56" rot="R180"/>
<instance part="Q5" gate="1" x="685.8" y="50.8"/>
<instance part="R9" gate="G$1" x="678.18" y="55.88" rot="R90"/>
<instance part="C11" gate="G$1" x="698.5" y="50.8"/>
<instance part="GND14" gate="GND" x="690.88" y="40.64"/>
<instance part="D17" gate="G$1" x="683.26" y="68.58" rot="R90"/>
<instance part="Q6" gate="1" x="690.88" y="-93.98"/>
<instance part="R10" gate="G$1" x="683.26" y="-88.9" rot="R90"/>
<instance part="C12" gate="G$1" x="703.58" y="-93.98"/>
<instance part="GND15" gate="GND" x="695.96" y="-104.14"/>
<instance part="D18" gate="G$1" x="688.34" y="-76.2" rot="R90"/>
<instance part="Q7" gate="1" x="594.36" y="-15.24"/>
<instance part="R11" gate="G$1" x="586.74" y="-10.16" rot="R90"/>
<instance part="C13" gate="G$1" x="607.06" y="-15.24"/>
<instance part="GND16" gate="GND" x="599.44" y="-25.4"/>
<instance part="D19" gate="G$1" x="591.82" y="2.54" rot="R90"/>
<instance part="T1" gate="G$1" x="375.92" y="210.82" rot="R90"/>
<instance part="R1" gate="G$1" x="365.76" y="203.2" rot="R90"/>
<instance part="SW1" gate="G$1" x="375.92" y="203.2"/>
<instance part="D1" gate="G$1" x="365.76" y="193.04" rot="R90"/>
<instance part="GND1" gate="GND" x="365.76" y="187.96"/>
<instance part="V10" gate="G$1" x="342.9" y="208.28"/>
<instance part="GND2" gate="GND" x="342.9" y="200.66"/>
<instance part="D2" gate="G$1" x="668.02" y="-91.44" rot="R270"/>
<instance part="D3" gate="G$1" x="678.18" y="48.26" rot="R90"/>
<instance part="V1" gate="G$1" x="690.88" y="71.12"/>
<instance part="V2" gate="G$1" x="784.86" y="2.54" rot="R180"/>
<instance part="V3" gate="G$1" x="695.96" y="-76.2"/>
<instance part="V4" gate="G$1" x="599.44" y="5.08" rot="R180"/>
<instance part="T2" gate="G$1" x="629.92" y="48.26"/>
<instance part="K1" gate="1" x="632.46" y="58.42"/>
<instance part="K1" gate="2" x="581.66" y="50.8" rot="R90"/>
<instance part="GND3" gate="GND" x="632.46" y="35.56"/>
<instance part="R3" gate="G$1" x="627.38" y="43.18" rot="R90"/>
<instance part="R4" gate="G$1" x="622.3" y="48.26" rot="R180"/>
<instance part="T3" gate="G$1" x="543.56" y="48.26" rot="R270"/>
<instance part="R5" gate="G$1" x="553.72" y="55.88" rot="R270"/>
<instance part="D5" gate="G$1" x="553.72" y="66.04" rot="R270"/>
<instance part="GND5" gate="GND" x="553.72" y="71.12" rot="R180"/>
</instances>
<busses>
</busses>
<nets>
<net name="GND" class="0">
<segment>
<pinref part="C4" gate="G$1" pin="-"/>
<wire x1="792.48" y1="-17.78" x2="792.48" y2="-22.86" width="0.1524" layer="91"/>
<pinref part="Q2" gate="1" pin="S"/>
<wire x1="792.48" y1="-22.86" x2="784.86" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="784.86" y1="-22.86" x2="782.32" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="782.32" y1="-22.86" x2="782.32" y2="-20.32" width="0.1524" layer="91"/>
<pinref part="GND4" gate="GND" pin="GND"/>
<junction x="784.86" y="-22.86"/>
</segment>
<segment>
<pinref part="IC4" gate="G$1" pin="9"/>
<pinref part="GND12" gate="GND" pin="GND"/>
<wire x1="401.32" y1="121.92" x2="401.32" y2="99.06" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="R7" gate="G$1" pin="1"/>
<wire x1="383.54" y1="157.48" x2="383.54" y2="160.02" width="0.1524" layer="91"/>
<pinref part="GND13" gate="GND" pin="GND"/>
</segment>
<segment>
<pinref part="C11" gate="G$1" pin="-"/>
<wire x1="698.5" y1="48.26" x2="698.5" y2="43.18" width="0.1524" layer="91"/>
<pinref part="Q5" gate="1" pin="S"/>
<wire x1="698.5" y1="43.18" x2="690.88" y2="43.18" width="0.1524" layer="91"/>
<wire x1="690.88" y1="43.18" x2="688.34" y2="43.18" width="0.1524" layer="91"/>
<wire x1="688.34" y1="43.18" x2="688.34" y2="45.72" width="0.1524" layer="91"/>
<pinref part="GND14" gate="GND" pin="GND"/>
<junction x="690.88" y="43.18"/>
</segment>
<segment>
<pinref part="C12" gate="G$1" pin="-"/>
<wire x1="703.58" y1="-96.52" x2="703.58" y2="-101.6" width="0.1524" layer="91"/>
<pinref part="Q6" gate="1" pin="S"/>
<wire x1="703.58" y1="-101.6" x2="695.96" y2="-101.6" width="0.1524" layer="91"/>
<wire x1="695.96" y1="-101.6" x2="693.42" y2="-101.6" width="0.1524" layer="91"/>
<wire x1="693.42" y1="-101.6" x2="693.42" y2="-99.06" width="0.1524" layer="91"/>
<pinref part="GND15" gate="GND" pin="GND"/>
<junction x="695.96" y="-101.6"/>
</segment>
<segment>
<pinref part="C13" gate="G$1" pin="-"/>
<wire x1="607.06" y1="-17.78" x2="607.06" y2="-22.86" width="0.1524" layer="91"/>
<pinref part="Q7" gate="1" pin="S"/>
<wire x1="607.06" y1="-22.86" x2="599.44" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="599.44" y1="-22.86" x2="596.9" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="596.9" y1="-22.86" x2="596.9" y2="-20.32" width="0.1524" layer="91"/>
<pinref part="GND16" gate="GND" pin="GND"/>
<junction x="599.44" y="-22.86"/>
</segment>
<segment>
<pinref part="D1" gate="G$1" pin="A"/>
<pinref part="GND1" gate="GND" pin="GND"/>
</segment>
<segment>
<pinref part="V10" gate="G$1" pin="-"/>
<pinref part="GND2" gate="GND" pin="GND"/>
</segment>
<segment>
<pinref part="T2" gate="G$1" pin="E"/>
<pinref part="GND3" gate="GND" pin="GND"/>
<pinref part="R3" gate="G$1" pin="1"/>
<wire x1="632.46" y1="38.1" x2="627.38" y2="38.1" width="0.1524" layer="91"/>
<wire x1="632.46" y1="38.1" x2="632.46" y2="43.18" width="0.1524" layer="91"/>
<junction x="632.46" y="38.1"/>
</segment>
<segment>
<pinref part="D5" gate="G$1" pin="A"/>
<pinref part="GND5" gate="GND" pin="GND"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="D16" gate="G$1" pin="C"/>
<pinref part="R7" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="D16" gate="G$1" pin="A"/>
<pinref part="IC4" gate="G$1" pin="17"/>
<wire x1="383.54" y1="139.7" x2="383.54" y2="137.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="R8" gate="G$1" pin="2"/>
<pinref part="IC4" gate="G$1" pin="16"/>
<wire x1="386.08" y1="147.32" x2="386.08" y2="137.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="15"/>
<wire x1="388.62" y1="137.16" x2="388.62" y2="157.48" width="0.1524" layer="91"/>
<pinref part="R8" gate="G$1" pin="1"/>
<wire x1="388.62" y1="157.48" x2="386.08" y2="157.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="11"/>
<wire x1="398.78" y1="137.16" x2="398.78" y2="149.86" width="0.1524" layer="91"/>
<wire x1="398.78" y1="149.86" x2="647.7" y2="149.86" width="0.1524" layer="91"/>
<wire x1="647.7" y1="149.86" x2="647.7" y2="-104.14" width="0.1524" layer="91"/>
<pinref part="Q6" gate="1" pin="G"/>
<pinref part="R10" gate="G$1" pin="1"/>
<wire x1="683.26" y1="-93.98" x2="685.8" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="683.26" y1="-93.98" x2="678.18" y2="-93.98" width="0.1524" layer="91"/>
<pinref part="D2" gate="G$1" pin="C"/>
<wire x1="678.18" y1="-93.98" x2="668.02" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="647.7" y1="-104.14" x2="678.18" y2="-104.14" width="0.1524" layer="91"/>
<wire x1="678.18" y1="-104.14" x2="678.18" y2="-93.98" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="10"/>
<wire x1="401.32" y1="137.16" x2="401.32" y2="144.78" width="0.1524" layer="91"/>
<wire x1="401.32" y1="144.78" x2="617.22" y2="144.78" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="617.22" y1="144.78" x2="617.22" y2="48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$50" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="18"/>
<wire x1="381" y1="213.36" x2="381" y2="195.58" width="0.1524" layer="91"/>
<pinref part="T1" gate="G$1" pin="E"/>
<wire x1="381" y1="195.58" x2="381" y2="177.8" width="0.1524" layer="91"/>
<wire x1="381" y1="177.8" x2="381" y2="137.16" width="0.1524" layer="91"/>
<wire x1="355.6" y1="193.04" x2="358.14" y2="193.04" width="0.1524" layer="91"/>
<wire x1="358.14" y1="193.04" x2="358.14" y2="177.8" width="0.1524" layer="91"/>
<wire x1="358.14" y1="177.8" x2="381" y2="177.8" width="0.1524" layer="91"/>
<pinref part="K1" gate="1" pin="1"/>
<wire x1="632.46" y1="63.5" x2="632.46" y2="195.58" width="0.1524" layer="91"/>
<wire x1="632.46" y1="195.58" x2="381" y2="195.58" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="14"/>
<wire x1="391.16" y1="137.16" x2="391.16" y2="167.64" width="0.1524" layer="91"/>
<wire x1="391.16" y1="167.64" x2="416.56" y2="167.64" width="0.1524" layer="91"/>
<wire x1="416.56" y1="167.64" x2="416.56" y2="187.96" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="Q2" gate="1" pin="G"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="772.16" y1="-15.24" x2="774.7" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="772.16" y1="-15.24" x2="772.16" y2="-119.38" width="0.1524" layer="91"/>
<pinref part="Q7" gate="1" pin="G"/>
<pinref part="R11" gate="G$1" pin="1"/>
<wire x1="586.74" y1="-15.24" x2="589.28" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="772.16" y1="-119.38" x2="652.78" y2="-119.38" width="0.1524" layer="91"/>
<wire x1="645.16" y1="-119.38" x2="586.74" y2="-119.38" width="0.1524" layer="91"/>
<wire x1="586.74" y1="-119.38" x2="586.74" y2="-15.24" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="12"/>
<wire x1="396.24" y1="137.16" x2="396.24" y2="154.94" width="0.1524" layer="91"/>
<wire x1="396.24" y1="154.94" x2="652.78" y2="154.94" width="0.1524" layer="91"/>
<wire x1="645.16" y1="-119.38" x2="652.78" y2="-119.38" width="0.1524" layer="91"/>
<wire x1="652.78" y1="-119.38" x2="652.78" y2="154.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="13"/>
<wire x1="393.7" y1="137.16" x2="393.7" y2="160.02" width="0.1524" layer="91"/>
<wire x1="393.7" y1="160.02" x2="668.02" y2="160.02" width="0.1524" layer="91"/>
<pinref part="D3" gate="G$1" pin="A"/>
<pinref part="D2" gate="G$1" pin="A"/>
<wire x1="678.18" y1="43.18" x2="668.02" y2="43.18" width="0.1524" layer="91"/>
<wire x1="668.02" y1="43.18" x2="668.02" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="668.02" y1="160.02" x2="668.02" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="R1" gate="G$1" pin="1"/>
<pinref part="D1" gate="G$1" pin="C"/>
<pinref part="SW1" gate="G$1" pin="P"/>
<wire x1="365.76" y1="198.12" x2="375.92" y2="198.12" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="T1" gate="G$1" pin="B"/>
<pinref part="SW1" gate="G$1" pin="S"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="Q5" gate="1" pin="G"/>
<pinref part="R9" gate="G$1" pin="1"/>
<wire x1="678.18" y1="50.8" x2="680.72" y2="50.8" width="0.1524" layer="91"/>
<pinref part="D3" gate="G$1" pin="C"/>
<junction x="678.18" y="50.8"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="Q5" gate="1" pin="D"/>
<pinref part="C11" gate="G$1" pin="+"/>
<wire x1="688.34" y1="55.88" x2="690.88" y2="55.88" width="0.1524" layer="91"/>
<pinref part="D17" gate="G$1" pin="A"/>
<wire x1="690.88" y1="55.88" x2="698.5" y2="55.88" width="0.1524" layer="91"/>
<wire x1="683.26" y1="63.5" x2="683.26" y2="55.88" width="0.1524" layer="91"/>
<wire x1="683.26" y1="55.88" x2="688.34" y2="55.88" width="0.1524" layer="91"/>
<wire x1="690.88" y1="66.04" x2="690.88" y2="55.88" width="0.1524" layer="91"/>
<pinref part="V1" gate="G$1" pin="-"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="Q2" gate="1" pin="D"/>
<pinref part="C4" gate="G$1" pin="+"/>
<pinref part="D4" gate="G$1" pin="A"/>
<wire x1="782.32" y1="-10.16" x2="784.86" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="784.86" y1="-10.16" x2="792.48" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="777.24" y1="-2.54" x2="777.24" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="777.24" y1="-10.16" x2="782.32" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="V2" gate="G$1" pin="+"/>
<wire x1="784.86" y1="-2.54" x2="784.86" y2="-10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="Q6" gate="1" pin="D"/>
<pinref part="C12" gate="G$1" pin="+"/>
<wire x1="693.42" y1="-88.9" x2="695.96" y2="-88.9" width="0.1524" layer="91"/>
<pinref part="D18" gate="G$1" pin="A"/>
<wire x1="695.96" y1="-88.9" x2="703.58" y2="-88.9" width="0.1524" layer="91"/>
<wire x1="688.34" y1="-81.28" x2="688.34" y2="-88.9" width="0.1524" layer="91"/>
<wire x1="688.34" y1="-88.9" x2="693.42" y2="-88.9" width="0.1524" layer="91"/>
<wire x1="695.96" y1="-81.28" x2="695.96" y2="-88.9" width="0.1524" layer="91"/>
<pinref part="V3" gate="G$1" pin="-"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="R10" gate="G$1" pin="2"/>
<pinref part="D18" gate="G$1" pin="C"/>
<wire x1="695.96" y1="-71.12" x2="695.96" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="695.96" y1="-63.5" x2="688.34" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="688.34" y1="-63.5" x2="688.34" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="688.34" y1="-63.5" x2="683.26" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="683.26" y1="-63.5" x2="683.26" y2="-83.82" width="0.1524" layer="91"/>
<pinref part="R11" gate="G$1" pin="2"/>
<wire x1="591.82" y1="15.24" x2="589.28" y2="15.24" width="0.1524" layer="91"/>
<wire x1="589.28" y1="15.24" x2="586.74" y2="15.24" width="0.1524" layer="91"/>
<wire x1="586.74" y1="15.24" x2="586.74" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="D19" gate="G$1" pin="C"/>
<wire x1="591.82" y1="15.24" x2="591.82" y2="5.08" width="0.1524" layer="91"/>
<wire x1="591.82" y1="15.24" x2="599.44" y2="15.24" width="0.1524" layer="91"/>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="599.44" y1="15.24" x2="713.74" y2="15.24" width="0.1524" layer="91"/>
<wire x1="690.88" y1="81.28" x2="683.26" y2="81.28" width="0.1524" layer="91"/>
<wire x1="683.26" y1="81.28" x2="678.18" y2="81.28" width="0.1524" layer="91"/>
<wire x1="678.18" y1="81.28" x2="678.18" y2="60.96" width="0.1524" layer="91"/>
<pinref part="D17" gate="G$1" pin="C"/>
<wire x1="683.26" y1="81.28" x2="683.26" y2="71.12" width="0.1524" layer="91"/>
<wire x1="690.88" y1="76.2" x2="690.88" y2="81.28" width="0.1524" layer="91"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="365.76" y1="208.28" x2="365.76" y2="213.36" width="0.1524" layer="91"/>
<pinref part="T1" gate="G$1" pin="C"/>
<wire x1="365.76" y1="213.36" x2="370.84" y2="213.36" width="0.1524" layer="91"/>
<wire x1="365.76" y1="213.36" x2="342.9" y2="213.36" width="0.1524" layer="91"/>
<pinref part="V10" gate="G$1" pin="+"/>
<wire x1="342.9" y1="213.36" x2="342.9" y2="236.22" width="0.1524" layer="91"/>
<wire x1="342.9" y1="236.22" x2="690.88" y2="236.22" width="0.1524" layer="91"/>
<wire x1="690.88" y1="236.22" x2="690.88" y2="81.28" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="2"/>
<wire x1="784.86" y1="15.24" x2="777.24" y2="15.24" width="0.1524" layer="91"/>
<wire x1="777.24" y1="15.24" x2="772.16" y2="15.24" width="0.1524" layer="91"/>
<wire x1="772.16" y1="15.24" x2="772.16" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="D4" gate="G$1" pin="C"/>
<wire x1="777.24" y1="15.24" x2="777.24" y2="5.08" width="0.1524" layer="91"/>
<wire x1="690.88" y1="81.28" x2="784.86" y2="81.28" width="0.1524" layer="91"/>
<wire x1="784.86" y1="81.28" x2="784.86" y2="15.24" width="0.1524" layer="91"/>
<wire x1="784.86" y1="15.24" x2="843.28" y2="15.24" width="0.1524" layer="91"/>
<wire x1="843.28" y1="15.24" x2="843.28" y2="-104.14" width="0.1524" layer="91"/>
<wire x1="843.28" y1="-104.14" x2="718.82" y2="-104.14" width="0.1524" layer="91"/>
<wire x1="718.82" y1="-104.14" x2="718.82" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="718.82" y1="-63.5" x2="713.74" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="716.28" y1="15.24" x2="713.74" y2="15.24" width="0.1524" layer="91"/>
<wire x1="713.74" y1="15.24" x2="713.74" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="695.96" y1="-63.5" x2="713.74" y2="-63.5" width="0.1524" layer="91"/>
<pinref part="V1" gate="G$1" pin="+"/>
<pinref part="V3" gate="G$1" pin="+"/>
<pinref part="V2" gate="G$1" pin="-"/>
<wire x1="784.86" y1="15.24" x2="784.86" y2="7.62" width="0.1524" layer="91"/>
<pinref part="V4" gate="G$1" pin="-"/>
<wire x1="599.44" y1="10.16" x2="599.44" y2="15.24" width="0.1524" layer="91"/>
<pinref part="K1" gate="2" pin="P"/>
<wire x1="586.74" y1="15.24" x2="584.2" y2="15.24" width="0.1524" layer="91"/>
<wire x1="584.2" y1="15.24" x2="584.2" y2="50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="Q7" gate="1" pin="D"/>
<pinref part="C13" gate="G$1" pin="+"/>
<pinref part="D19" gate="G$1" pin="A"/>
<wire x1="596.9" y1="-10.16" x2="599.44" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="599.44" y1="-10.16" x2="607.06" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="591.82" y1="-2.54" x2="591.82" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="591.82" y1="-10.16" x2="596.9" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="V4" gate="G$1" pin="+"/>
<wire x1="599.44" y1="0" x2="599.44" y2="-10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="K1" gate="1" pin="2"/>
<pinref part="T2" gate="G$1" pin="C"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="T2" gate="G$1" pin="B"/>
<pinref part="R3" gate="G$1" pin="2"/>
<pinref part="R4" gate="G$1" pin="1"/>
<junction x="627.38" y="48.26"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="R5" gate="G$1" pin="1"/>
<pinref part="D5" gate="G$1" pin="C"/>
<wire x1="553.72" y1="60.96" x2="543.56" y2="60.96" width="0.1524" layer="91"/>
<pinref part="T3" gate="G$1" pin="B"/>
<wire x1="543.56" y1="60.96" x2="543.56" y2="50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="R5" gate="G$1" pin="2"/>
<wire x1="553.72" y1="50.8" x2="553.72" y2="45.72" width="0.1524" layer="91"/>
<pinref part="T3" gate="G$1" pin="C"/>
<wire x1="553.72" y1="45.72" x2="548.64" y2="45.72" width="0.1524" layer="91"/>
<wire x1="553.72" y1="45.72" x2="576.58" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="T3" gate="G$1" pin="E"/>
<wire x1="538.48" y1="45.72" x2="518.16" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
