Electronics => Electronics => Topic started by: ccdjr106 on February 26, 2010, 05:43:02 PM
i have a poloulu reflectance sensor and ive been told that you need to charge the capacitor and then count how long it takes it to discharge it. what would be the code to do this on a arduino. and how would i beable to display that number on the serial monitor in the arduino software
thanks, CJ
Pololu QTR Reflectance Sensor Application Note
Information about using the Pololu QTR-xA and QTR-xRC reflectance sensors, including sample oscilloscope screen captures of sensor outputs. (http://www.pololu.com/docs/0J13)
Each QTR-1RC [http://www.pololu.com/catalog/product/959] and
QTR-8RC [http://www.pololu.com/catalog/product/961] reflectance sensor
phototransistor output is tied to a capacitor discharge circuit as shown
on the right, which allows a digital I/O line on a microcontroller to take
an analog reflectance reading by measuring the discharge time of the
capacitor. When you have a microcontroller’s digital I/O connected to a
sensor output, the typical sequence for reading that sensor is:
1. Set the I/O line to an output and drive it high
2. Allow at least 10 us for the 10 nF capacitor to charge
3. Make the I/O line an input (high impedance)
4. Measure the time for the capacitor to discharge by waiting for the
I/O line to go low
(http://www.pololu.com/picture/0J631.301.png)
A guide to using the Pololu QTRSensors library with Arduinos and Arduino-compatible devices like the Pololu Orangutan robot controllers.
http://www.pololu.com/docs/0J19 (http://www.pololu.com/docs/0J19)
http://www.pololu.com/docs/pdf/0J19/QTR_arduino_library.pdf (http://www.pololu.com/docs/pdf/0J19/QTR_arduino_library.pdf)
I/O line to go low
i know how to do steps 1-3 but how do i do 4 and what is a us in 2
In step 2, 10us is 10 micro-seconds.
Is better and easy to used the Pololu QTRSensors library from Pololu
Follow the guide to install the Lib and here is the code to output to serial monitor
#include <PololuQTRSensors.h>
// create an object for your type of sensor (RC or Analog)
// in this example we have three sensors on analog inputs 0 - 2, a.k.a. digital pins 14 - 16
PololuQTRSensorsRC qtr((unsigned char[]) {14, 15, 16}, 3);
// PololuQTRSensorsA qtr((unsigned char[]) {0, 1, 2}, 3);
void setup()
// optional: wait for some input from the user, such as a button press
// then start calibration phase and move the sensors over both
// reflectance extremes they will encounter in your application:
int i;
for (i = 0; i < 250; i++) // make the calibration take about 5 seconds
qtr.calibrate();
delay(20);
// optional: signal that the calibration phase is now over and wait for further
// input from the user, such as a button press
Serial.begin(9600);
void loop()
unsigned int sensors[3];
// get calibrated sensor values returned in the sensors array, along with the line position
// position will range from 0 to 2000, with 1000 corresponding to the line over the middle sensor
int position = qtr.readLine(sensors);
// output to Serial monitor
Serial.print(sensors[0]);
Serial.print(" ");
Serial.print(sensors[1]);
Serial.print(" ");
Serial.print(sensors[2]);
Serial.print(" ");
Serial.println();
// if all three sensors see very low reflectance, take some appropriate action for this situation
if (sensors[0] > 750 && sensors[1] > 750 && sensors[2] > 750)
// do something. Maybe this means we're at the edge of a course or about to fall off a table,
// in which case, we might want to stop moving, back up, and turn around.
return;
// compute our "error" from the line position. We will make it so that the error is zero when
// the middle sensor is over the line, because this is our goal. Error will range from
// -1000 to +1000. If we have sensor 0 on the left and sensor 2 on the right, a reading of -1000
// means that we see the line on the left and a reading of +1000 means we see the line on
// the right.
int error = position - 1000;
int leftMotorSpeed = 100;
int rightMotorSpeed = 100;
if (error < -500) // the line is on the left
leftMotorSpeed = 0; // turn left
if (error > 500) // the line is on the right
rightMotorSpeed = 0; // turn right
// set motor speeds using the two motor speed variables above
Here is the step 1 to 4 how there do it in the Pololu QTRSensors library
// Reads the sensor values into an array. There *MUST* be space
// for as many values as there were sensors specified in the constructor.
// Example usage:
// unsigned int sensor_values[8];
// sensors.read(sensor_values);
// The values returned are in microseconds and range from 0 to
// timeout_us (as specified in the constructor).
void PololuQTRSensorsRC::readPrivate(unsigned int *sensor_values)
unsigned char i;
unsigned char start_time;
unsigned char delta_time;
unsigned int time = 0;
unsigned char last_b = _portBMask;
unsigned char last_c = _portCMask;
unsigned char last_d = _portDMask;
// reset the values
for(i = 0; i < _numSensors; i++)
sensor_values[i] = 0;
// set all sensor pins to outputs
DDRB |= _portBMask;
DDRC |= _portCMask;
DDRD |= _portDMask;
// drive high for 10 us
PORTB |= _portBMask;
PORTC |= _portCMask;
PORTD |= _portDMask;
delayMicroseconds(10);
// set all ports to inputs
DDRB &= ~_portBMask;
DDRC &= ~_portCMask;
DDRD &= ~_portDMask;
// turn off pull ups
PORTB &= ~_portBMask;
PORTC &= ~_portCMask;
PORTD &= ~_portDMask;
unsigned char prevTCCR2A = TCCR2A;
unsigned char prevTCCR2B = TCCR2B;
TCCR2A |= 0x03;
TCCR2B = 0x02; // run timer2 in normal mode at 2.5 MHz
// this is compatible with OrangutanMotors
start_time = TCNT2;
while (time < _maxValue)
// Keep track of the total time.
// This explicitly casts the difference to unsigned char, so
// we don't add negative values.
delta_time = TCNT2 - start_time;
time += delta_time;
start_time += delta_time;
// continue immediately if there is no change
if (PINB == last_b && PINC == last_c && PIND == last_d)
continue;
// save the last observed values
last_b = PINB;
last_c = PINC;
last_d = PIND;
// figure out which pins changed
for (i = 0; i < _numSensors; i++)
if (sensor_values[i] == 0 && !(*_register[i] & _bitmask[i]))
sensor_values[i] = time;
TCCR2A = prevTCCR2A;
TCCR2B = prevTCCR2B;
if (!sensor_values[i])
sensor_values[i] = _maxValue;
for some reason i cant get the library installed i put it in documents/arduino/libraries im on my macbook pro
you extract it to your arduino-0018/hardware/libraries or
(arduino home folder)/hardware/libraries, and restart the Arduino app.
on my mac i searched for some of the other libraries that were showing up in the arduino program and i came up with the arduino folder that had the hardware/libraries in it and i saw all the libraries that were showing up in the arduino program . so i put the the pololu library folder in with the rest of them and its still not showing up ??? ???
i got the library installed but when i try to compile the first program i get a error: invalid conversion from 'char*' to 'unsigned char*'
how do i fix this i have absolutely no idea what it means
May I know which part of the program given this error? or you can show me your code.
You may read this "Type Casting" (http://www.cplusplus.com/doc/tutorial/typecasting/) for more info.
PololuQTRSensorsRC qtr((char[]) {14, 15, 16}, 3); it is the code that you gave me
You can change it to this will do
This is take from the demo code, I think it have some bug! :o
now is there a way to store the calibration so that i can calibrate it turn off the robot but still save the calibration data
EEPROM
http://www.arduino.cc/en/Reference/EEPROM (http://www.arduino.cc/en/Reference/EEPROM)
when i use the calibrate function where is the calibrated data stored
In the EEPROM. It is non-volatile memory, so even when you power off, the EEPROM data is still there. Write the calibration data to the EEPROM, and you can read it later.
i understand that but what variable is the calibration data stored in.
Refer the PololuQTRSensors.h here are variables that the calibration data stored
// Calibrated minumum and maximum values. These start at 1000 and
// 0, respectively, so that the very first sensor reading will
// update both of them.
// The pointers are unallocated until calibrate() is called, and
// then allocated to exactly the size required. Depending on the
// readMode argument to calibrate, only the On or Off values may
// be allocated, as required.
// These variables are made public so that you can use them for
// your own calculations and do things like saving the values to
// EEPROM, performing sanity checking, etc.
unsigned int *calibratedMinimumOn;
unsigned int *calibratedMaximumOn;
unsigned int *calibratedMinimumOff;
unsigned int *calibratedMaximumOff;Here are the code to output to serial monitor
for(i=0;i<3;i++) //number of Sensors
Serial.print(calibratedMaximumOn[i]);
Serial.print(" ");
Serial.print(calibratedMinimumOn[i]);
Serial.print(" ");
Serial.print(calibratedMaximumOff[i]);
Serial.print(" ");
Serial.print(calibratedMinimumOff[i]);
Serial.print(" ");
