Software => Software => Topic started by: ethought on March 07, 2010, 08:55:32 AM
Hi all -
A simple question I think.
Trying to get values for an analog sensor.
Using a Sharp IR analogue range sensor with an Atmega8.
At the moment I am only checking the ADCH value. But there are 2 bits returned ADCL and ADCH.
The question is how do I combine these into an integer?
#define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
int set_PORTD_bit(int position, int value);
int main (void)
DDRD = 0x03; // Set LED1 as output
//ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); // Set ADC prescalar to 128 - 125KHz sample rate @ 16MHz
ADMUX |= (1 << REFS0); // Set ADC reference to AVCC
ADMUX |= (1 << ADLAR); // Left adjust ADC result to allow easy 8 bit reading
// No MUX values needed to be changed to use ADC0
ADCSRA |= (1 << ADFR); // Set ADC to Free-Running Mode
ADCSRA |= (1 << ADEN); // Enable ADC
ADCSRA |= (1 << ADSC); // Start A2D Conversions
for(;;) // Loop Forever
// bits are ADCL and ADCH
if(ADCH < 140)
set_PORTD_bit(0,0);
set_PORTD_bit(1,0);
else
set_PORTD_bit(0,1);
_delay_ms(50);
set_PORTD_bit(0,0);
_delay_ms(50);
/// LED 2
set_PORTD_bit(1,1);
_delay_ms(50);
set_PORTD_bit(1,0);
_delay_ms(50);
// Sets or clears the bit in position 'position'
// either high or low (1 or 0) to match 'value'.
// Leaves all other bits in PORTB unchanged.
if (value == 0)
PORTD &= ~(1 << position); // Set bit position low
else
PORTD |= (1 << position); // Set high, leave others alone
return 1;
There are many ways to do this, it is easiest when you just think about each bit.
I was thinking you OR the ADCH into the lower 8 bits of a 16 bit integer (uint_16), shift those up 8, then OR the ADCL into the lower 8 bits again and you should have an integer.
Additionally you can take a peek at where the a2dConvert10bit() command is, there is a simple way that Admin converts them into an integer but I forgot how he did it.
Not 100% sure, but try including the Sensor.c file first:
#include "sensors.c"
That contains the configuration for Sharp IR Range sensor..
To detect the range, use:
int range = sharp_IR_interpret_GP2D12(a2dConvert8bit(7));
where, 'range' will give the distance in cm, and '7' is the analogue port that has the sensor plugged in.
Tried with this:
voltage_int = ADCL;
voltage_int += (ADCH << 8);
Seems to be much more accurate now but still not really reliable... (I have no serial connection so cannot see the actual integers being generated).
I will also try the sensors.c include. Thanks
Did you put a capacitor (10uF generally works well) across the sharp's power and ground?
No, I have not tried with a capacitor. I will try that. Thanks for the tip!
Also that black plastic looking case is actually a conductor. Try to make sure it is connected to ground as well.
