Electronics => Electronics => Topic started by: Cristi_Neagu on April 11, 2010, 11:05:14 AM
Hello.
I designed a board layout using EagleCAD, and i want to transfer it to PCB using this method:
http://www.societyofrobots.com/member_tutorials/node/103 (http://www.societyofrobots.com/member_tutorials/node/103)
How do i go about printing one of those nice layouts? Because if i just push print, i get layer colors, and other things. Is there a special way to print a layout, or do i hide layers that i don't need, and i make all layers that i need black? Also, can i make two-sided PCB's using the method above?
Thanks.
When you're ready to print, click print, then tick the box ''black'' lines and pads should be black now, i usually hide the component dimensions...
I don't know about two sided boards, i've never done any... :-X
Thanks for the reply.
As it turns out, my question has already been answered here:
http://www.societyofrobots.com/robotforum/index.php?topic=9741.0 (http://www.societyofrobots.com/robotforum/index.php?topic=9741.0)
Next time i'll do a better job of searching the forum. Sorry about this....
Thanks again for the reply
