Electronics => Electronics => Topic started by: Jak24 on May 28, 2010, 12:55:54 PM
Title: resistor ohm ?
Post by: Jak24 on May 28, 2010, 12:55:54 PM
hi !
i have this transistor :
http://www.fairchildsemi.com/ds/BC%2FBC547.pdf (http://www.fairchildsemi.com/ds/BC%2FBC547.pdf) (546)
and i need to use it in here :
http://interactive.usc.edu/members/phoberman/relayCircuit.gif (http://interactive.usc.edu/members/phoberman/relayCircuit.gif)
how much ohm should the resistor be, from base to the digital pin?
thanks
Regards
Jak24
Title: Re: resistor ohm ?
Post by: waltr on May 28, 2010, 06:37:24 PM
Ok, a bipolar transistor is a current controlled device. You set the current into the base (to the emitter) to control the current flow into the collector (reverse from a pnp).
The current gain is in the data sheet as hfe (DC current gain) which is between 110 and 800. When using the transistor as a switch use the lowest hfe value in the calculations to ensure transistor saturation. So the base current times hfe equals collector current (Ibe * hfe = Ic), where Ic is the max current needed to power the relay, or relay coil voltage divided by the relay coil resistance, Icoil = Vcoil/Rcoil.
The base resistor then sets (or limits) the base current. So base resistor value is the IO high voltage minus the base-emitter voltage (about 0.6V) divided by the required base current, R = ((ioV - Vb)/Ib).
Since I don't know the relay's coil resistance I can't calculate the base resistor value but instead gave you the information required to calculate the base resistor value.
Post by: Pratheek on May 28, 2010, 11:18:18 PM
Read these two excellent tutorials -
http://www.kpsec.freeuk.com/components/tran.htm (http://www.kpsec.freeuk.com/components/tran.htm)
http://www.kpsec.freeuk.com/trancirc.htm (http://www.kpsec.freeuk.com/trancirc.htm)
You should then be able to find the answer to your question.
Post by: Jak24 on May 31, 2010, 10:50:04 AM
HI
thanks for replies, this is the relay I'm using :
http://sea.com.ua/img/info/ningbo%20forward/JZC-21F%28NT70%29.pdf (http://sea.com.ua/img/info/ningbo%20forward/JZC-21F%28NT70%29.pdf)
(jzc-20f) its resistance is 400 ohm
uhm so my high is 4.8 - 0.6 =4.2 divided by base current?, I'm not sure how to calculate that...
this is the battery I'm using :http://www.all-battery.com/12v2600mahnimhbatterypack11620.aspx
thanks
Regards
Jak24
Post by: waltr on May 31, 2010, 01:48:40 PM
The base current needed is the Collect current divided by the Hfe (DC gain). The collector current will equal the relay coil current which can be calculated from Ohms law, I = E/R. So 5V across a 400 Ohm coil is 12.5mA. From the Data sheet (and my post above) base current = 12.5 /110 = 114uA. Base resistor = 4.2V/114uA = 36.96k Ohm max. This could be smaller since the wish is the have the transistor in saturation. So any resistor from about 10k to 36k Ohm will work.
Post by: Jak24 on June 01, 2010, 01:03:18 PM
HI
OK, but my relay is 12v so could you tell me if my calculations are correct?
12v / 400 ohm = 30mA
30 / 110 = 270uA
(i re-check the high volt it was 5.14) so 5.14/ 270 = 19 k Ohm max so 19 - 8 k should work
right?
thanks
Regards
Jak24
Post by: waltr on June 01, 2010, 01:45:00 PM
Ah....the schematic you posted showed +5V on the relay and you didn't say it was otherwise.
But you now did go through the calculations yourself.
19 to 8 k should work
yep.
