Mechanics and Construction => Mechanics and Construction => Topic started by: Jak24 on May 31, 2010, 11:48:52 AM
hi
What kind of wires do you suggest i use to connect these motors:
http://shop.maxonmotor.com/ishop/article/article/222049.xml (http://shop.maxonmotor.com/ishop/article/article/222049.xml)
and this motor
http://shop.maxonmotor.com/ishop/article/article/2516.800-11.111-000.xml (http://shop.maxonmotor.com/ishop/article/article/2516.800-11.111-000.xml)
i already have these wires but i don't know if they could handle the current :
http://www.radioshack.com/product/index.jsp?productId=2103801 (http://www.radioshack.com/product/index.jsp?productId=2103801)
this is the battery I'm using:
http://www.all-battery.com/12v2600mahnimhbatterypack11620.aspx (http://www.all-battery.com/12v2600mahnimhbatterypack11620.aspx) 7
PS: i want to solder the wires to the motors would this affect the wires in any way ?
thanks
Regards
Jak24
The battery has 18ga wire (hint, hint).
The first motor will draw almost 4Amp on starting and when stalled so 18ga is plenty. But, this is not the complete question.
What size fuze are you going to use? You do want the fuze to blow before the wire melts.
Second consideration is the voltage drop due to the wire resistance and current. How long are the wires?
If you google wire gauge you will find tables showing the max recommends current and the resistance per length of common sizes,
Her's one:http://www.powerstream.com/Wire_Size.htm
Soldering the wire to the motor terminals is recommended for the most secure mechanical and electrical connection.
HI
Thanks for reply
well technically I'm not going to use any fuse.....
but if you recommend it then i do have 5 - 6 amp fuses.
but if i don't use any fuses the wires I mentioned should work fine... right?
PS : so if battery is 18ga wire, that, or anything better would do fine?
Regards
Jak24
You should ALWAYS fuse off the battery, very bad things can happen (Not that I have any personal experience) ::)
OK but .... i mean how could there be a overload or a short, my battery always provides 12v(roughly)?
well if you think i really should use one, I'll put it in .
but back to the point :
the wires I mentioned should work fine... right?:
thanks
regards
Jak24
Murphy's law!
There are just too many ways to create a short or overload. Here's a few I've experienced:
Motor windings overheat and short together.
A component fails and shorts internally, caps, ICs.
A cap or IC is wired or inserted backwards.
Two wires get pinched together, cutting through the insulation and shorting.
Slipping with a screwdriver or other tool and shorting two contacts.
Connecting the wrong wires together.
Miscalculating a resistor value or misreading a resistor value that draws way too much current when the circuit is turned on.
Yes the battery will try to provide 12V but at what current? What happens when the load becomes close to zero Ohms? Hint: use Ohm's Law to calculate I. Then what happens at the battery?
HI
Murphy's law!
OK so : 12 / .... I'm not sure of the resistance, how do i calculate that? ..... = I
if i use 5-6 amp fuses they should do the job right?
Regards
Jak24
OHM's LAW, google it.
Anyway, if you tried to calculate the current you would find that with a resistance close to zero (say 0.01 Ohm) the current draw from the battery would go close to infinity (ok, only 1200Amps). This would severely overheat the battery and it could rupture and maybe even catch fire. That is if the wire didn't catch fire and burn off first.
Did you look at the wire table I posted the link to?
Will 18ga wire carry 5-6 amps?
HI
No 18 ga will not carry 5-6 amps : http://www.powerstream.com/Wire_Size.htm (http://www.powerstream.com/Wire_Size.htm)
it can only carry 2.3 amps for power transmitting.
i have fuses like this :
http://ecx.images-amazon.com/images/I/21G94RT1NvL._SL500_AA300_.jpg (http://ecx.images-amazon.com/images/I/21G94RT1NvL._SL500_AA300_.jpg)
and a fuse holder like this:
http://www.electronicsnmore.com/images/fuse-hl.gif (http://www.electronicsnmore.com/images/fuse-hl.gif)
(i going to plug the battery into a breadboard and attach a fuse to it (to the breadboard)
but if 18ga wire can't handle 5-6 amps then could you suggest a fuse that would work:
with this battery :
with these motors connected to it :
http://shop.maxonmotor.com/ishop/article/article/222049.xml (http://shop.maxonmotor.com/ishop/article/article/222049.xml) x 3
http://shop.maxonmotor.com/ishop/article/article/2516.800-11.111-000.xml (http://shop.maxonmotor.com/ishop/article/article/2516.800-11.111-000.xml) x 1
and for this battery :
http://www.all-battery.com/6v200mahnimhsidebysiderxreceiverbatterypackswhitecconnectorforrcaircraftswalkingrobot-2.aspx (http://www.all-battery.com/6v200mahnimhsidebysiderxreceiverbatterypackswhitecconnectorforrcaircraftswalkingrobot-2.aspx)
it's powering my micro-controller and my sensors.
please suggest a better fuses (what amp, slo - blow etc...)
i only want my fuse to protect the battery from frying up...
PS(sorry i ask so many questions it's just that this is my first robot project :P )
Regards
Jak24
Questions are good. I just try to get you to figured out the answers.
Look at the wire chart again. Power transmission means a very, very long piece of wire so it is the resistance and voltage drop that limits the recommended current to 2.3A.
Look at the column to the left titled "Maximum amps for chassis wiring". This is for shorter wires like on your bot. What is the max current under this condition?
it can handle 16 A ..... so with a 5-6A slow -blow fuse it should do the job? (the specs are in my previous post)
thanks
Regards
Jak24
Yep, you got it.
Hi
OK so any 5-6 amp(slow-blow) fuse for each battery (the 6v and 12v)
will stop any overloads or shorts right?
just making sure :D
regards
Jak24
