Electronics => Electronics => Topic started by: Jdog on June 30, 2010, 11:50:31 PM
I'm designing something in Eagle that uses a PIC16F1827. Unfortunately, this was not in Eagle's standard library, so I made it myself by copying the PIC16C84 which is Pin Compatible with the other MCU. So, I made my own library and added this part to it. But, when I'm in my schematic and go to add a part, this library does not show. But, when I look in the libraries from the control panel, it does show. Not knowing what to do, I added the same part to microchip's library, thinking I'd be able to find it. But I still don't see the part from the add part menu in a schematic, but once again I can see it from the control panel. Any thoughts on why this is happening and how to fix it?
A "part" in eagle consists of three things, a symbol, a package, and a device to link everything together. Dkd you make/copy all three of those?
When in the schematic part, click Library and then Use. Select the library you made and it will be available.
Thank you very much, that worked. :)
