Electronics => Electronics => Topic started by: Razor Concepts on July 31, 2010, 09:04:19 PM
Title: Looking for cheap liquid pump
Post by: Razor Concepts on July 31, 2010, 09:04:19 PM
I'm looking for a small and cheap electric water/liquid pump. From my RC background the cheapest I could find is this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVZ40&P=FR (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVZ40&P=FR)
Is there any other place I could find small and cheap pumps?
Title: Re: Looking for cheap liquid pump
Post by: amando96 on August 01, 2010, 05:41:14 AM
If you don't want to wait for a delivery go to a fish tank shop, they should have a line of cheap pumps.
Post by: dunk on August 01, 2010, 09:21:46 AM
car windscreen washer pump?
Post by: blackbeard on August 01, 2010, 09:39:49 AM
although dirt cheep don't expect much out of these. they will die after a minute of continuous use.
Post by: Soeren on August 01, 2010, 10:38:50 PM
If you buy  them "dirt cheap", perhaps you have your explanation  ;)
A windscreen washer pump was my first thought as well, as I have had two of them going for years (15..20 years actually), with much more than a minute at each run.
One bought from new (one of the better brands), the other ripped out of a Fiat going to the slaughter house.
Just don't feed them a higher voltage than designed for and if possible, go lower, as they are a bit noisy at rated voltage.
Post by: Soeren on August 01, 2010, 10:44:30 PM
What liquid and what volume/time and what voltage?
I have (somewhere) a small 8V (IIRC) AC pump that pumps in a very odd way - a spring is set to vibrate at the AC frequency in the core of a kind of solenoid.
Not the strongest flow, but amazingly silent for the volume it can muster.
Don't know if they are available these days, I got it way back in a hazy past.
Post by: Razor Concepts on August 04, 2010, 10:22:16 AM
Thanks for the suggestions! I just went ahead with the "top fueler" thing, I want to see how the DC pump works. I looked at the inside of a AC aquarium pump and its the same mechanism that Soeren described... too bad the pump was for air and not liquids.
Post by: blackbeard on August 04, 2010, 03:54:49 PM
to be fair i was using a wiper pump from a 1990's minivan to power a liquid cooling system for my computer and powering it from the psu.
