Software => Software => Topic started by: Henrique on October 14, 2010, 03:57:56 PM
Hi folks! ;D
Here is my problem, so if anyone can help I would be glad
I have two motors which will be controlled by my L298,
and i want control them with a variable speed.
But when i set my new speed to the actuators the motors just
don't make a movement ( and if make is just a little movement),
here is the code:
PS: with or without the "n" the problem persists.
main code:
#include "hardware.h" //iopin ,actuators , axon... are included here
// and 2 motors (right and left) are initilized here too.
#include "movements.h"
#include "controlManual.h"
#include "l298.h" //
//define the type of control
#define manual
void appInitHardware(void){
pin_make_output( E2, false );
pin_make_output( A4, false );
pin_make_output( H2, false );
pin_make_output( A5, false );
uartInit(UART1, 115200);
solarL298Init(&bank1);
rprintfInit(&uart1SendByte);
rprintfProgStrM("System Warmed UP. .Initialization Complete\n");
turnOnL298(); // this method turn on the pins of L298
act_setSpeed(&left,DRIVE_SPEED_MAX*0.5);
act_setSpeed(&right,DRIVE_SPEED_MAX*0.5);
return 0;
TICK_COUNT appControl(LOOP_COUNT loopCount, TICK_COUNT loopStart){
act_setSpeed(&left,DRIVE_SPEED_MAX * n);
act_setSpeed(&right,DRIVE_SPEED_MAX * n);
// this "n" is like a control of the speed , i want control the speed of
//each motor. and HERE IS THE PROBLEM (i think)!
//*0<=n<=1
#ifdef manual
controlManual();
#endif
return 1000000;
controlManual
void controlManual(){ // Get an key from keyboard.then the methods move , back , turn left ,turn
//right ,top , set the PINs true or false, to make the motor spin the way i want.
// Like if i press w, he will move forward then, i set values to my pin
char cByte = GET_DATA_USB;
switch ( cByte ){
case 'w':
move();
front();
break;
case 's':
move();
back();
break;
case 'd':
move();
turnRight();
break;
case 'a':
move();
turnLeft();
break;
default:
stop();
the methods, back , move, turnRight...
void front(){
pin_set( E2, false );
pin_set( H2, true );
void back(){
pin_set( E2, true );
pin_set( H2, false );
void turnRight(){
pin_set( E2, false);
void turnLeft(){
void stop(){
pin_low( A4 );
pin_low( A5 );
void move(){
pin_high( A4 );
pin_high( A5 );
sorry my english :-X
Instead of defining turn right/left/forward, etc by changing pins, do it by using act_setSpeed();
hey thanks dude!, another question:
after doing this , i only can go forward with my two motors, how can I go back?
the only comands i can give are like
act_setSpeed(&left,DRIVE_SPEED_MAX);
then he goes forward with the left wheel
but when i use de command
act_setSpeed(&left,DRIVE_SPEED_MIN);
nothing happens.
The command act_setSpeed(&left,DRIVE_SPEED_MIN); *should* make the motor go full speed in reverse . . .
Are you sure you got all the pins matching your wiring?
SOLAR_L298_MOTOR left = MAKE_SOLAR_L288_MOTOR(TRUE , E3,E2,A4);
Im using like this:
E3 = L1
E2 = L2
A4 = enable
SOLAR_L298_MOTOR right = MAKE_SOLAR_L298_MOTOR(FALSE, H3, H2,A5 );
H3 = L3
H2 = L4
A5 = ENABLE
based on the datasheet of L298:
http://www.solarbotics.com/assets/datasheets/solarbotics_l298_compact_motor_driver_kit.pdf (http://www.solarbotics.com/assets/datasheets/solarbotics_l298_compact_motor_driver_kit.pdf)
page 12
Oh damn you were right !
Now I set point pins as PWM E3 and H3, and A4, A5, C4 and C5 as I / O
the problem was the pin order in time to create the motor also.
anyway Thanks man!! you were helpfull.
