Software => Software => Topic started by: CUrules12 on October 31, 2010, 07:46:53 PM
Ok, so I bought the serial port to usb adapter because no computer in my house has a male header serial port
I plugged in the Dongle programmer...and Pony Prog wont write the source code!
What do I do?
what do you mean ponyprog wont write the source code. Be more specific. Have you tried ALL of your USB ports(I believe i read this could cause a problem)
PonyProg pops up with a box that says Writing 0% and it stays at 0 %, and then the program goes to "Not Responding"
okay i assume you're using usb.. try switch to a different usb port if you have multiple and try it in every port
also post pics of the bottom of your robot board in case there is a bad connection
