Electronics => Electronics => Topic started by: WhomBom on December 07, 2010, 03:05:22 PM
Hi guys, i'm looking for a bit of an extreme accelerometer; it should be able to measure up to 500g ideally, 250g at least.
It's sample frequency would be 48kHz ideally, but at least 10kHz.
Does anyone have an idea where i can buy a sensor that would meet my requirements? anything close to them would be ok as well ;)
Just out of curiosity and for a better understanding what will this sensor be used for(application) I assume you mean 500 grams and not 500G's?
If that is the case most accelerometers will do the job. it is just a matter of how many axis of measurment you want.1,2 or 3.
http://www.sparkfun.com/categories/80 (http://www.sparkfun.com/categories/80)
Commonly most accelerometers at that level are about 2-3 G, if you expect to pull more G's than that you will have to look into some diiferent accelerometers.
There are Piezo sensors that are used to measure the G's at high frequency during vibration testing.
Many sources from googling "Piezo vibration sensors".
Hi guys, @joker: no, i mean G's ;D
application for this is to measure the recoil of a large caliber rifle, that's why i need the range and crazy sampling frequency.
Sparkfun has a single axis 250G sensor but it's sampling rate is at 300Hz or something... the recoil only lasts for a ms or so hence i'd probably completely miss it at 300Hz.
Tri-axis would be perfect, but i'm afraid high sampling frequencies and lots of data (3 directions instead of 1) aren't going to be friends. Nor do i expect 3 axis to be friendly on my wallet ::)
@waltr, i found this; http://www.vibrametrics.com/downloads/Individual%20Spec%20Sheets/Model%201000%20Series.pdf (http://www.vibrametrics.com/downloads/Individual%20Spec%20Sheets/Model%201000%20Series.pdf)
it says it has a broad frequency range, does this also mean it outputs it's data at said frequencies? e.g. I don't want it to measure a 20kHz vibration and the transmit the data that it is sensing a 20kHz vibration at 500Hz, i want the actual G's!
WhomBom
That sensor you linked to has an analog voltage output (see first line of data sheet where it says 10mV/g). This is purely a voltage verse time domain. This could be connected to an O'scope or to a high speed ADC.
