Software => Software => Topic started by: ksquared on December 28, 2010, 04:02:10 PM
Edit: My own lack of attention to detail is what caused this. Sorry... I did this on a breadboard with the LED in the right place (ie, on a PWM pin) and when I did this on my permanent $50 dollar bot board, I didn't realize I had moved the L.E.D. on my breadboard.
Whoops.
BTW, thanks, that was the answer I was looking for anyhows...
I was trying to program some PWM for the first time in a long time (although I thought I had it working earlier this year.)
Some pins seem designated PWM; some pins do not. Try:
(http://arduino.cc/en/uploads/Hacking/Atmega168PinMap2.png)
or just use the reference sheet from this tutorial: http://www.societyofrobots.com/member_tutorials/node/233 (http://www.societyofrobots.com/member_tutorials/node/233)
However this tutorial http://www.societyofrobots.com/member_tutorials/node/226 (http://www.societyofrobots.com/member_tutorials/node/226) has a subroutine that goes starts like this:
void pwmInit56(void) { // Pin 6 is channel A and Pin 5 is channel B
Which seems to imply that hardware PWM can be put on Pin 6, for example, which does not seem to be a PWM pin. Is this true? Are there limitations to this? I'm actually pretty confused; I couldn't find anything in that code which would seem to change the pins around.
Oh, and thanks in Advance for any help!
The picture you linked is the Arduino pin mappings, so is this a generic AVR PWM question or a Arduino pin question?
The Atmega only has 6 pins available for hardware PWM, via the 2 channels of 3 timers. PD3,6,7 and PB1,2,3.
