Electronics => Electronics => Topic started by: Paul F on January 25, 2011, 08:31:51 PM
Title: Motor Speed Range
Post by: Paul F on January 25, 2011, 08:31:51 PM
Good Day,
I want to build a pan/tilt head for a 5 lb. camera on a 16' jib. I have this motor  http://www.servocity.com/html/51_rpm_gear_motor.html (http://www.servocity.com/html/51_rpm_gear_motor.html) and this motor controller http://www.pololu.com/catalog/product/1392. (http://www.pololu.com/catalog/product/1392.) I'm controlling it with a joystick. The range of speed control is not satisfactory. I want to be able to control the pan movement such that I can go from imperceptibly slow to fast enough to track someone running.
On a professional TV camera, the zoom function has this range. I can creep in at an almost imperceptibly slow rate to a very fast zoom.
Worse, the motor starts off with a sudden start. I can't get it to start up easy no matter what I do. I have used a DC power supply with very fine voltage adjustments. It also has a sudden start and I cannot get the motor to creep along.
How is it that the zoom on a camera lens can go so very slow, but I cannot control this motor in the same fashion?
Thanks.
Title: Re: Motor Speed Range
Post by: rbtying on January 26, 2011, 09:28:47 AM
The DC motor you picked is rated at 51RPM.  I am guessing that you'd like to move at something more like a minimum of 3 or 4 rpm - you'll want to gear down for that, such that the motor shaft is reduced around 10x.
http://www.servocity.com/html/gearmotor_gearbox.html (http://www.servocity.com/html/gearmotor_gearbox.html) (from the same page) may work well - its 8.45:1.
Post by: Soeren on January 26, 2011, 01:42:06 PM
How slow does it have to be before being below your threshold of perception?
And how fast is the runner and at what distance?
There's a world of difference between following Ben Johnson close up and a senior citizen 500m away.
IOW, what's the speed limits in °/s?
Usually, you start panning a bit early and begin the take when speed is stabilized, or you can edit it away later. In a setup with more than one cam , the editor (person) won't switch to a cam before its picture is stable.
If you need to start panning while filming, you just need a controlled start-up ramp.
The cam was designed and built by engineers (with the backing of an entire company), that probably have done a fair bit of motor control circuits.
Post by: Paul F on January 26, 2011, 09:48:19 PM
Consider that in one case I have a wide angle lens and someone is walking close to the camera. A 90 degree pan might take 5 seconds.
Consider in another case I have a 150mm(35mm equiv) telephoto and want to slowly pan the horizon. That same 90 degree movement might take 1 minute. It needs to be very slow. Slower than the current geared motor can provide.
The solution is to use a slower motor, but then the upper range is now too slow. The motor I have now is satisfactory  for the high speed work. It is not satisfactory for the slower pans. I could use two motors, but that is of course, not ideal.
My experience with professional broadcast camera zoom lenses tells me the range I want and the control I want should be possible.
Indeed, but I thought that is what I was getting with the Pololu motor controller. Do you have any recommendations?
Post by: Soeren on January 26, 2011, 11:19:09 PM
Slower is easy... Gear reduction and/or PWM control.
The range is not really all that large 5..60s is just 1:12 - very easy with PWM control, so just select the reduction to fit the max. speed and let PWM handle the 100% down to 8.3% range.
If you wanted a purely mechanical solution (like 2 motors) you could just as well make it with an arrangement of small pulleys in the fashion done on a drill press with 2 or more sets of pulleys (or a fine pitch timing belt with suitable toothed wheels.
My experience with BC cams (which don't need the pro in front, as all BC equipment is pro by the very nature ;)) tells me that if you want that quality, you need a huge wallet. Thinking you can make a kitchen sink equivalent is very-very optimistic, unless you are a savvy engineer, knows the subject in your sleep and have a very well equipped workshop.
So, how are your skills in mech. engineering and how well equipped are you with power tools (like lathes, mills and routers)?
I take pride in constructing most of what I need, to get covered on the parameters I need, rather than buy ready made, so I cannot recommend you to buy product X over product Y, as I have no experience with neither of them.
I can however tell you how to make such stuff, if you are into electrical (and mechanical) engineering and have a well equipped workshop.
How did you set up your tests?
They need to be with a full load, so use some bricks or whatever (to spare your cam), and run some tests where you add two well planed circular plates of say 100mm (4") in diameter and assemble them with a high viscocity silicone grease as a brake - BC tripod heads use this method to help steadying the pan (and tilt) when used by a (human) cam operator.
Have you downloaded the data sheet for the controller?
And did you exhaust the possibilities in the controller set-up software?
It seems to have plenty of options... On the "motor" tab, you can set tyhe max. acceleration (and that might be just the ticket) and on the PID tab, you can play around with the parameters for P, I and D (Proportional, Integral and Differential gain) parameters.
Note the initial values and don't change more than one parameter in any one go (even if you are well versed in control engineering).
Try this first and if that won't do it, a combination of mechanical and electronic solutions can be tried.
You might wanna gear the motor down to the max. speed before playing with the controller software, as that will make it stronger (and the "grease plates" will cure lots of vibration/unevenness, so won't be a bad idea either).
You are controlling it with R/C protocol pulses, right?
Post by: Paul F on January 27, 2011, 05:31:15 PM
Thanks for the input. I am very hands on with mechanical (I have a lathe & mill) and electronics. But I have so many projects, I just don't have time to design my own motor controller. So I'm looking for a quick fix. I'll play with the PID more and see if I can get what I need. I'm glad to hear you say I should be able to get the control I need with PWM. It seems I should get the Pololu to do what I want. I'm just not successful yet.
Cheers,
Post by: Soeren on January 30, 2011, 07:30:26 AM
Any luck decreasing the max. acceleration value?
Post by: Paul F on February 17, 2011, 09:05:48 PM
No. I ended up buying a lower RPM geared motor. I'm not happy, but that's what I have for now. I need to find a motor controller that has a better PWM range.
thanks for asking.
