Electronics => Electronics => Topic started by: manut on January 30, 2011, 06:49:33 AM
hi everybody,
I read on this page http://www.active-robots.com/products/sensors/sensors-sharp.shtml (http://www.active-robots.com/products/sensors/sensors-sharp.shtml) that the SHARP GP2Y0A02YK Distance Measuring Sensor could accurately determines range to target between 20cm and 150cm, but it's written below "Can be used as a proximity detector to detect objects between 0cm and 250cm"... so, what does it mean?it measures between 20 and 150 or 0 and 250? or is there a trickto convert the 20-->150 into 0-->250?
I'm going to use it with an arduino board.
Thanx
[...] but it's written below "Can be used as a proximity detector to detect objects between 0cm and 250cm"... so, what does it mean?
You're asking us what they mean?
We could try some wild guesses (but I don't believe it will reach out to 2.5m, for a reliable detect/no-detect), but you really ought to ask them.
http://www.societyofrobots.com/sensors_sharpirrange.shtml (http://www.societyofrobots.com/sensors_sharpirrange.shtml)
The Data Sheet for the sensor from Sharp is the last word so read that. Figure 3 shows the voltage for distance and only goes to 150 cm.
The Active Robots blurb could easily be a typo.
I doubt it. This is repeated for each of the range sensors, eg. the GP2D12
Infrared distance measuring sensor accurately determines range to target between 10cm and 80cm.
Can be used as a proximity detector to detect objects between 0cm and 130cm.
The GP2D120
Accurately determines range to target between 4cm and 30cm.
Can be used as a proximity detector to detect objects between 0cm and 50cm.
The GP2Y0A21YK
All sixty-some% longer range that should show something above noise ???
They can all detect down to 0cm (just not give the correct distance), but I doubt that there will be useful proximity data at 250cm, as the beam will have spread so much that random ground reflections will come into play and would probably mean a varying signal even without an obstacle - for a small slow-ish 'bot, 2.5m is not what I'd call proximity anyway.
