Electronics => Electronics => Topic started by: BANE on February 05, 2011, 11:37:46 AM
Hello all,
i have a regular ps2 controller (no mad cat crap) and this connector from lynxmotion. I have some questions about the colors of the wires since this diagram (the connector that i have) http://www.lynxmotion.com/images/html/build034.htm (http://www.lynxmotion.com/images/html/build034.htm)does not match this document http://webbot.org.uk/WebbotLibDocs/39767.html (http://webbot.org.uk/WebbotLibDocs/39767.html)
Here is what i have so far:
yellow-----------+5VDC
red&shield-------ground
white------------SCK ??
blue-------------select ??
orange----------MOSI ??
brown-----------MISO ??
any thoughts?
thanks in advance
hurray for trail and error :P it turns out i was right the first time
just for the records, anyone else who has this ps2 connector from lyxnmotion and want to connect it to the Axon II, here is the color diagram.
white------------SCK aka Clock
blue-------------select aka attention
orange----------MOSI aka Command
brown-----------MISO aka Data
Glad you got it working. There have actually been several versions of these cables. Lynxmotion does have it documented in several places. The place I usually look is on their Bot Board 2 documentation: http://www.lynxmotion.com/images/html/build151.htm#aglance (http://www.lynxmotion.com/images/html/build151.htm#aglance)
Kurt
P.S - I personally prefer working with the Lynxmotion wireless controller or the Madcatz over the original Sony wired as the original one was not consistent on the values returned from the joysticks. That is when you move a joystick and release it, such that it should go back to center, one time it might return to 123 and the next to 130... Where most of the other controllers returned back to a a reasonably consistent middle...
