Electronics => Electronics => Topic started by: Redcap on March 08, 2011, 04:57:00 AM
Hey all,
I've found some resistors laying around, but the value has rubbed off the container I had them in.
Because I'm colorblind, I find it very difficult to (correctly) tell what color the bands are in order to find out the values.
Is there any way I can find the value without having to rely on the color bands..? :(
Thanks in advance,
Redcap
I know I can use a multimeter to find out how much resistance it has, but how do I know if this is within the 10% tolerance or if the resistor is damaged?
You are probably aware of the fact that resistors come in different preffered number ranges (e.g. E6 series, E12, E24, etc.). Commonly, the E6 series is used for 20% tolerances, E12 for 10%, and E24 for 5%. Most color blind people can still typically see the differences on the tolerance bands (None, Gold, or Silver). If they are 10% tolerance resistors that would limit the values to the E12 range: 10 12 15 18 22 27 33 39 47 56 68 82. With only 12 possible combinations per decade, your best guess on the color values (even if color blind) combined with a multimeter reading is likely to give you a pretty good idea of the correct value, particularly if you have several of the same value resistors.
For example, you have a resistor with no tolerance band making it a 20% tolerance resistor and placing it in the E6 series (10 15 22 33 47 68).
The first two bands could be red or orange, but you can't tell. RED-RED would be 22 which is part of the E6 series, RED-ORANGE or ORANGE-RED would be 23 or 32 respectively, which aren't part of the E6 series so we can discount those possibilities. ORANGE-ORANGE would be 33 which is also part of the E6 series.
So given 22 or 33 as the possible resistor value. With a 20% tolerance that would give us a range of 17.6 to 26.4 for RED-RED or 26.4 to 39.6 for ORANGE-ORANGE.
Lastly we look at our multiplier band and compare with a multimeter reading. For example if its yellow, you would have a multiplier of 10^4.
Your multimeter reading is 36.2Kohms, which places it solidly in the ORANGE-ORANGE range. After measuring a couple more resistors they all fall within the ORANGE-ORANGE range so you can be confident that they are all ORANGE-ORANGE-YELLOW resistors and are all within the 20% tolerance.
You only need to know tolerances for manufacturing purposes, meaning you can be sure that the batch will fit within a certain range.
The multimeter will give you an exact value, making the tolerance a useless value for a small project.
That said, if you measure a few thousand resistors and write down the value of each, you'll find them within X% off from a specific value, giving you the tolerance.
Thank you both very much for your replies :)
knossos, thanks for taking the time to write that reply. You've made a lot of things "click" and have given me a very solid starting point for future reference.
-Re-reading what I wrote in my question, I've worded it badly, but both have given answers I was needing, cheers :)
