Electronics => Electronics => Topic started by: gshubham96 on June 20, 2011, 03:56:41 AM
Title: atmega328-+-atmega8
Post by: gshubham96 on June 20, 2011, 03:56:41 AM
Hello,
Me and my friend are making a robot.The problem is that he works with atmega8, while i have arduino uno based on atmega 328. my question, can we transmit data b/w them?
the arduino uno will be on the transmitter side with the atmega 8 at the reciever side or vice-versa. we will be communicating through RF.
what will be the circuit and coding??
any help is appreciated
Shubham(http://)
Title: Re: atmega328-+-atmega8
Post by: Soeren on June 21, 2011, 04:39:35 PM
Sure, data is always just "0" and "1" on the root level, so you could even exchange data with a Cyber 205 (which you probably don't know ;D)
You just have to establish a common protocol for the data exchange to make it meaningful.
Using regular serial transmission on both, with eg. 2400 bps, 1 stop bit and no parity, should do.
The circuit you'll find in the datasheet for your specific transmitter and receiver modules, but it's probably just 0V, +5V, data in and a pin for the antenna on the transmitter and something similar on the receiver.
The coding will depend of the coding language, which you didn't mention, but will be regular serial transmit and receive commands.
Post by: gshubham96 on June 22, 2011, 11:53:32 AM
Thx.. for the reply, i figured out how to do it, and i used processing lang ( virtualwire.h library)
