Software => Software => Topic started by: NGuggemos on August 29, 2011, 08:40:06 AM
I'm programming the Axon II in project designer using Webbotlib. When it asks for my battery and I'm using a switching regulator should I type the output voltage and current of the switching regulator or should I put the initial voltage of my battery?
Yep - enter the output voltage and current of your supply - ie what you are going to 'plug in' to the AxonII.
So I should enter the voltage and current after its regulated by the switching regulator?
Yes
ok thank you
