Electronics => Electronics => Topic started by: ModMob on September 24, 2011, 10:51:17 AM
Title: Need USB Virtual Serial Communication with Game Controller
Post by: ModMob on September 24, 2011, 10:51:17 AM
Hello,
I have a setup where I’m using MATLAB for some computing on my PC; then I send and receive information with my three mobile robots via an XBee point to multi-point network.  This part works, because the coordinator XBee appears as a virtual serial COM on my PC.  I also want to use a USB game controller, but MATLAB can only communicate with a USB device if it appears as a virtual serial COM port.
So, I need a gamepad or gamepad driver that can emulate a serial port, but I haven’t found a quick solution.  I have Logitech F310 gamepad and it doesn’t support this.  I would use any gamepad that has two joysticks and at least 6 other inputs.
Does anyone know if any of the common USB gamepads appear as a virtual serial COM on your PC?
Any info helps...
Cheers,
Mod
Title: Re: Need USB Virtual Serial Communication with Game Controller
Post by: rbtying on September 24, 2011, 11:16:31 AM
Have you looked into this (http://tech.groups.yahoo.com/group/psychtoolbox/message/581)? I find it hard to believe that Matlab has no support for USB joysticks.
As far as I know, no USB joystick/gamepad will have a usb-to-serial interface, simply because the USB specification already defines a joystick interface, which is generally preferred.
Post by: ModMob on September 24, 2011, 11:46:08 AM
No I hadn't.  Looks promising.  My assumption about MATLAB not supporting USB is from:
http://www.mathworks.com/support/solutions/en/data/1-195HX/?solution=1-195HX (http://www.mathworks.com/support/solutions/en/data/1-195HX/?solution=1-195HX)
I'm no expert, so maybe there is a straight forward way. I have heard of some support for specific types of joysticks and more complicated solutions.  The controller interfacing is something I need for my research, but not the topic, so I'm looking for a quick and easy way to do it.
Thanks for your advice.
