Software => Software => Topic started by: pk44 on November 08, 2011, 03:31:59 PM
I am trying to get the ping sensor to work with the axon using my own code because the official ping code is still in beta. I want to read the pulse from the sensor with a arduino-style pulsein() function and then convert that into range data. while writing my code i found that the actual timer functions in the source code differ from what is in the documentation on the axon web page. I do not think that my digital input or output is working because the activity light on the sensor never blinks. So there are a number of things that could be wrong with my code, but i was hoping someone could help me figure this out, because the only sensors readily available to me are ping ultrasonic sensors. here is my code:
#include "SoR_Utils.h"
#include "sensors.c"
#include "rprintf.h"
#include "uart4.h"
int pulsein(char port, int pin, int hl)
if(hl == 0)
if(port == 'A')
while(bit_is_set(PINA, pin))
init_timer1(TIMER_CLK_1);
while(bit_is_clear(PINA, pin))
int pulse = get_timer1_overflow()*255+TCNT1;
reset_timer1();
return pulse;
else if(port == 'E')
while(bit_is_set(PINE, pin))
while(bit_is_clear(PINE, pin))
reset_timer1();
return pulse;
else if(port == 'H')
while(bit_is_set(PINH, pin))
while(bit_is_clear(PINH, pin))
reset_timer1();
return pulse;
else if(port == 'C')
while(bit_is_set(PINC, pin))
while(bit_is_clear(PINC, pin))
reset_timer1();
return pulse;
else if(hl == 1)
if(port == 'A')
reset_timer1();
return pulse;
reset_timer1();
return pulse;
reset_timer1();
return pulse;
reset_timer1();
return pulse;
//only attach ping to pin 5
int readpingcm(char port)
long duration;
long cm;
if(port == 'A')
//output
DDRA = _BV(PA5);
PORT_OFF(PORTA, 5);
delay_us(2);
PORT_ON(PORTA, 5);
delay_us(5);
PORT_OFF(PORTA, 5);
//input
cbi(DDRA, PA5);
duration = pulsein('A', 5, 1);
cm = duration/29/2;
return cm;
//output
DDRE = _BV(PE5);
PORT_OFF(PORTE, 5);
delay_us(2);
PORT_ON(PORTE, 5);
delay_us(5);
PORT_OFF(PORTE, 5);
//input
cbi(DDRE, PE5);
cm = duration/29/2;
return cm;
//output
DDRH = _BV(PH5);
PORT_OFF(PORTH, 5);
delay_us(2);
PORT_ON(PORTH, 5);
delay_us(5);
PORT_OFF(PORTH, 5);
//input
cbi(DDRH, PH5);
cm = duration/29/2;
return cm;
//output
DDRC = _BV(PC5);
PORT_OFF(PORTC, 5);
delay_us(2);
PORT_ON(PORTC, 5);
delay_us(5);
PORT_OFF(PORTC, 5);
//input
cbi(DDRC, PC5);
cm = duration/29/2;
return cm;
int main(void)
uartInit();
uartSetBaudRate(1, 115200);
//initialize analog to digital converter
a2dInit();
//configure ADC scaling
a2dSetPrescaler(ADC_PRESCALE_DIV32);
//configure ADC reference voltage
a2dSetReference(ADC_REFERENCE_AVCC);
while(1)
int range = readpingcm('A');
rprintfInit(uart1SendByte);
rprintf("%d",range);
return 0;
thanks for any help!
I've gotten them to work with code much like that at http://www.arduino.cc/en/Tutorial/UltrasoundSensor (http://www.arduino.cc/en/Tutorial/UltrasoundSensor) To do it without looping you'll probably need to use the timer's input capture facility.
One of the problems I had with it was that it needs some time to startup. I can't recall how much it took but I think it was a few milliseconds before the first reading.
I haven't used one for a while now, and this is all straight from memory (which isn't working as well as it used to), so take it for what it's worth.
Joe
WebbotLib supports it as well (http://www.webbot.org.uk (http://www.webbot.org.uk)) and automatically takes cares of the one-off start up delay as well as the receommended delay between reads to avoid ghost echoes.
actually, i might not need this anymore. I managed to get arduino running on the axon using the arduino_extras files on avr-developers.org, i skipped the bootloader and used an avr-ispmkii and avrdude. The axon has the same pinout as the arduino mega so i used that as a reference and got it communicating with my computer over Serial1(uart1). I would still like to get my code working though, just to finish it...
sorry, avr-developers.com, not .org. and thanks for your suggestions!
