Mechanics and Construction => Mechanics and Construction => Topic started by: eiritsu on November 22, 2011, 09:11:09 PM
Title: Fast linear solenoid/piston/actuator
Post by: eiritsu on November 22, 2011, 09:11:09 PM
I am looking for a way to make a linear solenoid/piston that moves fast.
As fast as a solenoid would normally move.
The purpose for it is to make my robot's eyelids blink.
So you can imagine, it needs to be fast, like a flicking motion.
I already have the robot face and eyelids so there is a definite amount of space for the solenoid.
I'm currently using a 6mm stroke mini solenoid but the eye lids needs to move 1 inch upwards and downwards.
I'll post pictures of what I build shortly, I'm on my mobile right now.
If possible, I need a solenoid that has a stroke of at least 1 inch.
Where can I buy one which isn't as big as my hand? It's got to fit behind the eye of my robot which is about normal human size.
Title: Re: Fast linear solenoid/piston/actuator
Post by: Soeren on November 22, 2011, 09:34:50 PM
Normal eyelids aren't 1".
The average eye ball is a little less than an inch in diameter - closer to 24mm, and the eye lid doesn't cover the full diameter.
Even if it did, your 6mm solenoid may be quite fine, if it's strong enough (but with a balanced mechanical setup it should be), as you can just "lever it up".
Like this:
S--o--------E
Where S is the solenoid "attack point", o is the pivot point and E is where the eyelid goes.
I'm not sure what you mean by "a definite amount of space for the solenoid", as this will always be the case ???
