Electronics => Electronics => Topic started by: fugrammer on July 10, 2007, 02:13:10 AM
hi. i am building a circuit that requires 12vdc and a few amp. My original plan was to use a adapter capable of delivering that amount of power. However, althought its output is rated as 12v, i measured 18v. Can i still use it for the circuit? And why is the difference is huge?
AC Adaptors (or "wall warts" as they are often called) are usually unregulated. You usually need to run the power from these through a voltage regulator to get the precise voltage you want. You will also need a few filter capacitors as well to ensure a clean, consistent supply. Depending on what your circuit is, you may need to attach a heat sink to the voltage regulator. If you provide a schematic or more details of your circuit, we can recommend a voltage regulator that would suit your needs.
yeah you can used that ..i had a similar problem.What i did was to shift the adaptor output to 9 volts..and actually it gave me 11.5 volts..good enough right..try something like this in your adaptor too.
