Software => Software => Topic started by: icy on January 10, 2012, 08:36:38 PM
I'm new to using Bluetooth, and for my project I want to send and receive data back and forth between the Bluetooth Mate Silver (interfaced with Arduino) and my bluetooth-enabled computer. I want data (let's say just a single predefined number) to be automatically transmitted from the computer to the Bluetooth Mate, and then once it's received, the Bluetooth Mate sends a number back to the computer, and this continues forever in a loop. My goal is to find the time it takes from the computer sending a signal to the time it receives a signal back. Any suggestions on where to start? Thanks! ;D
Are you using Windows? If so you'll probably be unable to do two-way communication using the computer's bluetooth. To do two-way, you would need to have the Bluetooth Mate Silvers at both ends. Ultimately, in software, what you're doing is exactly the same as having a serial cable (or usb-serial cable) connecting the computer and the Arduino... You will just have a wireless serial cable via the bluetooth connection. (So what I'm saying is, learn how to do serial communications back and forth)
Yes I'm using Windows...I ultimately want to communicate back and forth in that way using two Bluetooth Mates with each attached to an Arduino, I just thought I could use my computer to test out the program before buying another Bluetooth Mate. If I were to use two Bluetooth Mates, do you have any advice? The online tutorials I'm finding are of course not geared for what I want to do, and are just about getting the Bluetooth Mate in command mode...
Thank you 8)
What I was attempting to say in my initial post is that bluetooth serial ports do not need special programming. You can still do 1-way bluetooth with your computer's bluetooth, though.
I'm not sure what kind of tutorials you're looking for/finding.
Do you know how to connect the components you're working with? (e.g. bluetooth mate silver to arduino, and bluetooth mate silver to computer)
I have one Bluetooth Mate Silver and two Arduinos, so I need to buy another Bluetooth Mate Silver that I will connect to the other Arduino. I know how to connect it to the Arduino. I'm just not sure where to start for the task I want to do, which would require 2-way communication.
