Electronics => Electronics => Topic started by: RITESH29 on January 19, 2012, 09:40:24 AM
Title: About servo control.....
Post by: RITESH29 on January 19, 2012, 09:40:24 AM
Hi All,
I am using servo motor with uC called propeller the are like blinking LED tested at all max and min delay but it not working well vibrating......
I am using 5V supply and GND to uC GND control pin to out port of uC..
Plaese tell what to remember while using servo!!
Title: Re: About servo control.....
Post by: newInRobotics on January 19, 2012, 11:22:17 AM
What is frequency of PWM that You are using?
Post by: RITESH29 on January 19, 2012, 11:42:00 AM
I was not using PWM it was simple on/off output like blinking of LED with delay and wait..
Post by: newInRobotics on January 19, 2012, 02:10:26 PM
OK, for how long pin is ON and for how long pin is OFF?
Post by: RITESH29 on January 19, 2012, 09:26:17 PM
Hi again,
I have change the duty cycle from sec to m Sec then microsec....
Post by: newInRobotics on January 20, 2012, 01:43:03 AM
By changing size of pulse (s, ms, us) You changed frequency and not duty cycle.
Most servos run @ 50Hz which is 20ms cycle. If You want to have 50% duty cycle:
for(;;;)
      set(PIN1);
      delay_ms(10);
      clear(PIN1);
      delay_ms(10);
Post by: RITESH29 on January 20, 2012, 02:25:57 AM
That mean it require PWM...!!
and what is inside a servo circuit what use of it??
Post by: newInRobotics on January 20, 2012, 02:58:06 AM
It doesn't have to be hardware PWM, You can simulate PWM by using delay() command, however for delay command to work properly, You must know and define clock speed. What uC are You using?
I don't understand Your question.
Post by: Soeren on January 20, 2012, 03:02:01 PM
That would have changed duty cycle as well.
A servo requires PDM (Pulse Duration Modulation). You may call it PWM, but with PWM you expect something like a 0..100% duty cycle, while in PDM you have a basic repetition rate (frequency) and a varying pulse duration/width.
The circuit inside a servo translates the servo pulses to position information, looks at the actual position information (from the potentiometer on the output axle) and controls the motor to move to the wanted position.
The servo pulses should have a repetition speed of around 20ms (50Hz), but quite some tolerance is accepted. The pulses is specified to 1.0ms to 2.0ms, although several servo manufacturers screw up the standard, so some go down to around 0.5ms and some go to around 2.8ms - but if you feed a servo a pulse that is either wider or more narrow than what it accepts, it will do its best to commit suicide by stripping its gears trying to push through the physical end stops, so keep within the 1.0ms to 2.0ms for starters. Also don't try to make the repetition speed much faster, or you'll ruin the servo a well.
If you find it easier, just make the inter-pulse pause ~ 18..19ms and then keep the pulse between 1.0ms and 2.0ms.
Post by: newInRobotics on January 20, 2012, 08:17:42 PM
How's that? Duty cycle is ratio between width of HIGH and LOW signals, so no matter if widths are 2s and 18s, or 2ms and 18ms, or 2us and 18us, duty cycle is still the same - 10%.
Post by: Soeren on January 20, 2012, 08:37:32 PM
Admittedly, RITESH29 wrote "I have change the duty cycle from sec to m Sec then microsec....", but you obviously caught the gist of it the same way I did (probably because you don't measure duty cycle in time units), judging from your remark "By changing size of pulse (s, ms, us) [...]".
So, if it was the pulse length he changed, but kept the pause length (since he didn't mention it) it would change the duty cycle as well as the frequency - an assumption on my side of course and while we could get it cleared up with RITESH29, I think we agree on the general aspects and just interpreted the statements differently :)
Post by: newInRobotics on January 21, 2012, 02:22:37 PM
So, if it was the pulse length he changed, but kept the pause length (since he didn't mention it) it would change the duty cycle as well as the frequency [...]
Now I get it  :D
Post by: Pogertt on January 22, 2012, 05:18:19 PM
Changing the value of 1500 at the end of the tHa line of code to 500 will drive the servo to 0 degrees.  Changing the value to 2500 will move the servo to 180 degrees.
This code comes from the parallax web site.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/101/Default.aspx (http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/101/Default.aspx)
{{ CenterParallaxServo.spin
For centering Parallax Continuous Rotation Servo
or holding Parallax Standard Servo at 90° position.
Sends a 1.5 ms pulse approx every 20 ms }}
CON
_clkmode = xtal1 + pll16x                 ' System clock → 80 MHz
_xinfreq = 5_000_000                      ' Using 5 MHz external crystal oscillator
servoPin = 0                              ' Servo signal to this I/O pin-change if needed
PUB CenterServo | tInc, tc, tHa, t
ctra[30..26] := %00100                    ' Configure Counter A to NCO
ctra[8..0]   := servoPin
frqa := 1
dira[servoPin]~~
' Set up cycle and high times
tInc := clkfreq/1_000_000
tC   := tInc * 21_500
tHa  := tInc * 1500
t    := cnt                               ' Mark counter time
repeat                                    ' Repeat PWM signal
  phsa := -tHa                            ' Set up the pulse
  t += tC                                 ' Calculate next cycle repeat
  waitcnt(t)                              ' Wait for next cycle
Post by: RITESH29 on January 27, 2012, 10:20:33 PM
Thanks for the code, i will try it..!!
Post by: RITESH29 on April 01, 2012, 10:55:49 AM
Hi again,
I have notice inside servo there was a 3terminal motor, can you please tell what type of motor is that???
