Electronics => Electronics => Topic started by: dmehling on July 23, 2007, 02:06:09 PM
I am looking for an inexpensive solenoid. It needs to be a pull type with a stroke distance of about 3 inches. I am open to other actuators, but I need linear movement and a spring to hold an object in place after current has been shut off.
I dont think you will find any above about 1 inch. I think what you want is a motor that uses a worm gear and a linear rod.
otherwise . . .
Check the google ads on this page:
http://www.societyofrobots.com/actuators_solenoids.shtml
Some of the places on this page has solenoids:
http://www.societyofrobots.com/robot_parts_list_motors_servos.shtml
If I can't use a solenoid, then what are some other ways of using an actuator with a spring mechanism? I am trying to build a clamp and need an actuator to hold it open, so that when electrical current is not applied to the actuator the clamp will automatically close.
Again, use a worm gear. When power is off, the worm gear still holds. It will hold better than any spring, too.
For example:
http://www.linearmotion.skf.com/en/8/fam-cat2106fid311-Magforce.html
Basically a worm gear drives a normal gear, and this normal gear drives a linear rod with teeth in it. This page has a good animated example, but it takes forever to load:
http://www.li-xiang.com.tw/new_page_88.htm
