Electronics => Electronics => Topic started by: Chocotwilight on October 11, 2012, 09:45:22 PM
Hi! I'm working on a lego meteorite harvester project and i'm a little confused about the IR range sensor. I attached it to the servo to get a constant scanning of area but i have no idea how to code it. After it scanned, what do i need to make it in when it detected an array of values?
void main()
while(!start_button());
while(1)
int array[15];
int i;
printf("Testing IR range value! \n");
for(i=0;i<15;i++)
array= analog(5);
printf("value =%d\n",array);
while((!start_button())&&(!stop_button()));
if(stop_button()) break;
this is the code i make to see the value it gets.
void main()
printf("Bumper test!!\n");
while(1)
check_distance();
void check_distance()
int irval = analog(IRFinder);
//If there is wall, value approx.50-110
//if there isn't wall, value approx 0
if(irval> 50) //to be set later
go_straight();
else
go_back();
msleep(1000L);
turn_around();
this is the command i make whether it detects something or not.I know i am suppose to get something like "0 0 0 0 1 1 1 1 0 0 0 0" if there is something infront but when i test the value it just give me something like "39 39 39 39 39 39 39 39 39".
I have no idea what to do with it, it would be great if someone here can help me with it! =)
Software questions belong in the forum marked "Software" (surprise ;)) and please put the source code in code-tags (the button with the hash sign "#" above the text field where you write the message).
