Electronics => Electronics => Topic started by: joefish41 on January 27, 2013, 02:08:49 PM
hi, im new to this site and wanted some advice or help! i am building a robot form wheelchair parts, ie, im useing 4, 24volt motors, 2 motor controllers and wanted to wire it all into 1 joystick, ???? can this be done? any advice or help would be a great help. thanks
Which controllers are you using? Link to data sheet.
Do they have resistive control inputs?
What function do you want the motors to do when the Joystick is non-centered?
This would be fairly easy to do using a micro-controller. the joystick's two pots feed a variable voltage to the u-controller's ADC inputs. Then based of the measured ADC values send info the the motor controllers.
joefish41, if you also got the controller(with a joystick) that came with the motors, you could use that.
the sweet thing about using wheelchair controllers is all the built in safeties.
Tommy
hi guys, thanks for the advice, the 4 motors, 2 controllers and the 1 joystick came from 2 identical wheelchairs they are quite old controllers and joystick, they are penny + giles d49464/5 controllers, what i had planed to is use both controller, with both the wiring looms from the chairs and wire the looms into 1 joystick, speed control but i wasnt sure if this would work? or if the 2 controllers would be to much for the 1 joystick, speed control, im not that cleaver when it come to electronics as i am new to all this kind of stuff???
joefish41, if both controllers share a common power source I could see it working(IMO 90% chance).
the P&G controllers are programmed for a particular acceleration/deceleration and speed profiles for
different users, chances are your going to have to have them reprogrammed to operate the same(cost me $50.00Us).
Tommy
thanks for the advice guys, i will be starting the project in a few weeks, i will keep you updared as the project gose on, thanks everybody
