Electronics => Electronics => Topic started by: Mastermime on February 20, 2013, 07:01:04 PM
Hi guys,
Last question for this project.
I am building this charging circuit (left side of schematic) and I feel like I am doing something wrong. Perhaps shorting something out?
I feel like something is up with my transistor configuration is up. My understanding of them is not complete, but I thought I got the gist of it
Please help quick
I think the NPN has the collector/emitter reversed if you consider the battery a load for the charger. Using a MOSFET may be better. You also need a current limiting resistor on the base, and perhaps a base bleed resistor between base and ground, too.
What is supposed to happen when the switch is left vs right? As far as I can tell, when the switch is left, it will attempt to parallel the two batteries, whereas when it is right, it will attempt to series them.
Btw: I would not hook that circuit to the rest of the pieces until it worked exactly like I want. Too much risk of burning things!
Thank you for such a quick response. You are exactly right, run in series, charge in parallel (I only have a 7.2v charger).
I'm not sure if its my schematic skills or my misunderstanding. In my circuit, I have emitter connected to ground of the top battery and the collector connected to the ground line of the charger. Is this correct?
I think my schematic is correct. No shorts right? I dont want to ruin the batteries.
I dont!
What are You trying to achieve with Your charger-transistor-batteries circuit?
The implicit answer I deduce from above is to be able to charge the batteries without removing them using only a 7.2V charger.
The arrow in a transistor should point in the direction of conventional current. When charging, conventional current will go the other direction than the transistor arrow points.
