Electronics => Electronics => Topic started by: hazzer123 on August 08, 2007, 01:57:09 AM
I need to amplify a signal that varies around the range 2.4-2.6 volts, so that it outputs 0 - 5V.
I understand the basic circuit where the gain is 1+ (R2/R1), but i want an offset, where 2.4V into the V+ pin creates 0V on the output pin (and vice versa with 2.6V in = 5V out).
Any one have any ideas?
My op-amp has no balance pins.
So, you need a gain of ((5-0)/(2.6-2.4)) = 25, with an offset of -2.4V.
The offset will also see the amplication factor, so you need to add an offset of only -2.4/25 = -96 mV.
Since it's a negative numbe, easiest way is to lift your inverting input by 96 mV (since inverting a minus yeilds positive).
Another method Ive used is to have two seperate grounds.
Set the amplifier circuit ground to 0V, and set your microcontroller ground to 2.4V.
To do that, you would use a 2.4V regulator for microcontroller ground, and a 5V+2.4V regulator for the positive voltage of your microcontroller.
Then just design your amplifier gain to not go above the 5V+2.4V voltage.
Ok maybe not elegant, but it works really well!
