Electronics => Electronics => Topic started by: ChristianKjaergaard on September 24, 2014, 03:02:05 PM
Hi
I just found a lot of these motors, but I can´t find a datasheet on maxon´s website. Maybe you guys know how to identyfy the motor.
What i can measure.
Weight: 100g
diameter: 26mm
Resistance: 8 Ohm
Best regards
Christian
Also measure length.
The problem with surplus Maxon motors is that most of these were custom to someone's specs. Therefore the PN will not be in the catalog. Best you can do is measure dimensions, Current draw and RPM at a set Voltage. Then try to find a "stock" motor.
Have you tried calling Maxon?
