Electronics => Electronics => Topic started by: extreme.aly on March 10, 2015, 07:19:28 AM
Hello people,
I tried googling this but I cannot find the datasheet for the encoder that comes with Pololu's 37dx52l Motor.
I'm trying to use that encoder to get motor speed on a Beaglebone Black which is 3.3V tolerant. So I made a voltage divider circuit with 1K and 2K ohm resistors. But for some reason, it is giving me way less than 3.3V.. Like 1.3V on the output of the voltage divider.
I noticed that the original signal, 5V expected, also changed to 2V. (2V*2/3 = 1.3V)...
Can anyone suggest a solution for properly dropping down the voltage to 3.3V for this Motor Encoder's output?
Are you powering the encoder with 3.3v (encoder Vcc, blue wire)?
how are you measuring the voltage of the encoder signal?
I'm powering the encoder using 5V.
I was measuring the voltage between GND and the encoder out pin.
I found a way to fix it. I used 10k and 20k ohm resistors instead of 1k and 2k.
My theory says that the encoder was not able to supply enough current, so the voltage was dropping. I used resistors of higher value so that less current is drawn. Lesser voltage is dropped.
:) Hello!
Check out this site;
https://www.pololu.com/product/1102 (https://www.pololu.com/product/1102)
Site with integrated encoder;
https://www.pololu.com/product/1442 (https://www.pololu.com/product/1442)
The specs are;
Dimensions
Size: 37D x 64L mm
Weight: 7.5 oz
Shaft diameter: 6 mm
General specifications
Gear ratio: 19:1
Free-run speed @ 6V: 256 rpm1
Free-run current @ 6V: 250 mA1
Stall current @ 6V: 2500 mA1
Stall torque @ 6V: 42 oz·in1
Free-run speed @ 12V: 500 rpm
Free-run current @ 12V: 300 mA
Stall current @ 12V: 5000 mA
Stall torque @ 12V: 84 oz·in
Lead length: 11 in
;D ;D ;D Hope this helps on the parameters of the
motor. ;D ;D ;D
:) Hello!
The specs are;
Dimensions
Size: 37D x 64L mm
Weight: 7.5 oz
Gear ratio: 19:1
Lead length: 11 in
motor. ;D ;D ;D
Obviously I have seen this page. I'm talking about the datasheet of it's encoder. This page doesn't mention the part # of the hall sensor encoder it is using.
sounds like a reasonable explanation to me, glad you figured it out.
I would not be surprised if the encoder is a custom board (as it is soldered directly to the motor). If you still need additional information regarding the encoder i would try contacting Pololu, if this is a custom encoder board they might be able to supply part numbers for the components they used.
Hello.
Just curious. Were you able to try any higher resistor values, like 50K and 100K?
My favorite resistor divider calculator.
http://www.voltagedivider.ca (http://www.voltagedivider.ca)
Thanks,
Dan
