Electronics => Electronics => Topic started by: bukowski on December 04, 2007, 12:33:24 PM
I cant view the video of the IR Rangefinder upgrade. Does the scanning servo input connect to pin 4 of the ATmega8? (and Im assuming that the rangefinder plugs into pin 27, replacing one of the photoresistors)
Thanks,
-Buk
If you look at the main code, it will say which pin it is. You will see one line that reads an analog value from a specific pin and stores that value into a variable.
You can therefore change it to whatever pin you like by changing it in code.
(If you still can't figure it out after looking at the code, Ill tell you)
OK, im not going to lie. My programming experience is nil, but I think that you have the rangefinder input going to pin 26 because you have the variable a2dConvert8bit(3) going to PC3. I cant seem to find where the scanning servo gets plugged into.
pin 26, yeap thats it.
For the scanning servo, try looking in SoR_Utils.h
hint: servo_scan(scan_angle);
Hmmm. I see a line "port_on(portd, 2);"
So im gonna take a leap of faith.
I see one of the pins called PD2, which is pin 4. I'll give that a shot. Im guessing that even if its wrong, I wont really hurt anything.
Sorry for bugging you admin, and thanks for the help.
I think im being overly cautious with this because ive already fried one chip, and i only have one backup, and Ive got to be done by thursday.
I had faith in you so thats why I didn't give you the answer directly :)
And I understand your over-cautiousness . . . I've fried chips too, and I often put on safety goggles whenever I turn on a circuit for the first time . . . :P
Anyway, now that you know how to read sensors and command servos in code, you can upgrade with more goodies in the future.
