Electronics => Electronics => Topic started by: fynflood on December 31, 2007, 06:59:17 AM
Title: H-Bridge/Arduino question
Post by: fynflood on December 31, 2007, 06:59:17 AM
I'm a noob, so bear with me  ;D
I'm building a bot with an Arduino. I'll be using 2 dc motors to drive it. I've made 2 h-bridges to control them. My questions is, can the h-bridge handle variable speeds. or is it ON and OFF?
I'm using the 6 transistor h-bridge, I'm not sure if that matters any. I guess I need to know if I should be using a digital output with PWM or not. I'd like it to go faster if there isn't anything nearby.
Title: Re: H-Bridge/Arduino question
Post by: Admin on December 31, 2007, 04:22:37 PM
yeap you want to use PWM, which is basically turning your motor on and off really really fast. By varying the on/off ratio, you can effectively vary the speed of your motor.
don't H-bridges have only 4 transistors? :P
Post by: fynflood on December 31, 2007, 05:27:58 PM
Thanks! Now I've got to figure out how to code the thing ; )
I built a couple of these:
(http://www.beam-online.com/Robots/Circuits/images/H-bridge_free.gif)
They're easy, and I had the stuff laying around
Post by: airman00 on December 31, 2007, 07:53:32 PM
lol transistors switching on other transistors in your schematic
wat robot are you making?
Post by: fynflood on January 01, 2008, 01:09:44 PM
what robot are you making?
Just a little guy that moves about, some basic obstacle avoiding. Something wrong with the schematic? It's been around for years.
Post by: airman00 on January 01, 2008, 01:21:13 PM
the schematic is fine, just you could have used 4 transistors, the 6 transistors makes it slightly easier to use
with 4 u would switch 2 transistors at a time with 6 u would switch one at a time ( that one transistor controlled two others)
its a bit difficult to explain without a drawing, so whatever
the h bridge you made is fine  :)
Post by: Half Shell on January 01, 2008, 03:58:00 PM
fynflood, you should drop me a message sometime. I've built a few robots doing arduino and am actually planning to build a few more soon.
http://itp.nyu.edu/physcomp/Labs/DCMotorControl
This tutorial uses the Texas Instruments SN75440NE dual h bridge. It has complete schematics and shows you code for arduino to on getting variable control.
I hope this helps. Feel free to contact me for help and I would love to know how the bot comes out.
Post by: maverick monk on January 02, 2008, 02:47:10 PM
sorry to threadjack, but for simpler programming can you use simple on/off commands???
also,can simple i/o commands be used on pins labled pwm on the arduino board?
Post by: Half Shell on January 02, 2008, 03:40:01 PM
I'm not entirely sure if I understand what you're asking, but I'll try my best to answer it.
If you want your motor to simply go full power or off, then you can merely use digitalWrite(#, HIGH); or digitalWrite(#, LOW); where # is the pin # you are outputting on the Arduino.
For the pins of the arduino that are labeled as PWM pins, you can declare them as outputs and merely use the analogWrite(#, #); The first # is the pin that you have it plugged into and the second # is an integer from 0 to 255. The PWM will be variable speed.
