Mechanics and Construction => Mechanics and Construction => Topic started by: cooldog on January 16, 2008, 05:38:29 PM
Title: max servo weight
Post by: cooldog on January 16, 2008, 05:38:29 PM
does anyone have any idea how much weight a HS-311 servo can hold without breaking
Title: Re: max servo weight
Post by: SmAsH on January 16, 2008, 05:52:12 PM
by breaking do you mean snapping or not being able to move?
~smash
Post by: cooldog on January 16, 2008, 06:11:04 PM
what ever comes first
Post by: SmAsH on January 16, 2008, 06:44:26 PM
well torque will definatley come into the "not moving" category. but snapping would take quite a bit of weight.
have you searched it on google?
Post by: cooldog on January 16, 2008, 06:49:51 PM
ya no luck
Post by: Admin on January 17, 2008, 07:50:54 AM
Its not weight, but torque that you are looking for.
Check the Hitec website for torque specs.
Torque = distance away from center of rotation * force
force is weight
Post by: airman00 on January 17, 2008, 11:10:21 AM
hs-311 has 49 oz/in of torque . Thats 3.0625 pounds / in
so  49    >  distance from motor shaft * weight of object at that distance away
NOTE:  distance should be measured in inches and weight should be measured in ounces
Ex. at 6" long servo arm can only have an object weighing 8 ounces at the end.
More than that the servo won't turn and the gears will grind.
