Electronics => Electronics => Topic started by: mohamed on February 10, 2008, 02:30:00 PM
now after i connected the circuit i discover i had to put the red wire on theleft and the black wire on the right but i replace them with each other but i done the connections right according to my wireing
so do i have to start from the beginning again or i can contiue and then i reverse the L293D on the dip socket or what shall i do?!! plz answer me fast as i have to get this project tomorrow
PS:here is a pic to my circuit of bottom view
if you have done all other connections right you can go on. If you have a black wire where a red wire should be it doesn't matter. it is useful for debugging a circuit tho
and i dont have to reverse the L293D when i place it on the dip socket
if you have made the connections like you are supposed to (I think you have) you should place the chip in like so (scroll down) http://www.societyofrobots.com/member_tutorials/node/66
if you haven't done the connections right, redo it! don't take a chances.
I think the connections are alright.
