Software => Software => Topic started by: silo_xtreme on February 12, 2008, 06:18:17 PM
Hi all,
In a2d.h the compiler has a problem with line 140
//! return TRUE if conversion is complete
u08 a2dIsComplete(void);
Any ideas?
probably
u08 = a2dIsComplete(void);
not the case. it works with the makefile that comes with the $50 robot. It's a return type, i just want to use a different chip....
u08 means int, or 8 bit int
use this to change from $50 ATmega8 code to code for your microcontroller:
http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml
admin,
where / what library is u08 defined?
Its part of the C language, as defined by gnc :P
doing this:
is the same as this:
int a2dIsComplete(void);
admin,
thanks! I guess the silly AVR Studio 4 doesn't know u08 ?
Which microcontroller are you using?
Did you change all of the code to reflect that microcontroller?
What is the exact error you are getting?
I've changed all the ports and timing files
I'm using the Atmega 2560 ...
I have the following error:
C:\..\..\Program Files\AVRlib/a2d.h:141: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'a2dIsComplete'
It compiles with your makefile , just not with settings in the AVR Studio ....
I wanted to try to compile it in the studio, because I'm not able to get debug values back over the JTAG interface properly....
Admin,
After searching I found this:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=58058
Was this you? ;) If so, did you ever get that new .h file working?
hmm .... really no more ideas?
yeap, that avrfreaks post basically highlights the solution
excellent. Oh, after updating AVR Studio and putting the "globals.h" header before the others - it finally works no problem.
Thanks again for all your help!
