Electronics => Electronics => Topic started by: mohamed on March 06, 2008, 09:45:35 PM
now i got my servos which are HS-322HD and they said that is has speed 0.19sec/60 at 4.8v,torque 3kg-cm
it has 0.15sec/60 at 6v and torque 3.7kg-cm, aslo i got 6 1.2v and 2000ma batteries from radioshack.
my questions are:
1.can i use 5 batteries from the one i got=6v to power whole robot or not?
2.is the HS-322HD servo is good for the robot,also can it be modified like the one in the tutorial or it has another way.
Thanks for your help...
If you use 6V then you don;t need a voltage regulator
( that is assuming AVRs , like PICs , run at up to 6volts)
HS-322HD are good servos, and they can be modified the same way. I used those servos on my 3 in 1 robot (picture is in my signature)
Thanks airman for ur reply....and btw nice robot i really hope that i can reach this level oneday ;D
now i have checked the ATmega 8 datasheet and i found that the operating voltage is 5.5v...so i can use the 5 batteries but i have to put the voltage regulator right?
wrong
a voltage regulator needs 2 volts higher to work right. SO a 5v regulator needs 7V coming in.
I think the ATmega 8 can handle the 6V though
But I need to know the minimum and maximum voltages it could handle. Then I can give you the best solution
it says in the datasheet that the ATmega8L can handle voltage from 2.7-5.5v
so what do u think?
I say connect a diode ( which usually have a 1 volt drop) between the batteries and the microcontroller
If you are using a microcontroller, no, you need a voltage regulator! Without a fixed voltage, the timer will be all whack, and the ADC won't be consistant.
All voltage regulators have a 'dropout voltage', typically 1.5V. An LDO, or low dropout, can be as low as .15V. I use a .3V LDO on one of my microcontrollers.
Yes, if you use a LDO regulator.
Whoops, I've been used to using PIC chips with built-in-regulators like the PIC16F616 ( my personal favorite) .
Yea you're right admin ;) ::)
