Electronics => Electronics => Topic started by: Ghost Recon King on March 27, 2008, 07:37:20 PM
If I want to make a robot with multiple moving parts, do I need a CPU and an OS to process the information from various microcontrollers ? If I need a CPU can it be a computer CPU?
Depends on how many sensors and moving parts. A single microcontroller can handle several servos and multiple sensor inputs. Depends on what kind of inputs you have and what microcontroller you use. For really big programs like roborealm for camera analysis or complex navigation using GPS and location sensors and a large amount of sensors you might need more then one microcontroller. If you do you still do not need a PC because you can dedicate a separate controller to coordinate them all. But those are large projects, your standard small robot project only needs one controller.
Can you give me a simpler explanation on how to make a sensor for a line following robot ?
$50 robot tutorial
http://www.societyofrobots.com/step_by_step_robot.shtml
I mean a set of detailed instructions and guidelines for making type of color sensor.
http://www.societyofrobots.com/member_tutorials/node/55
or
http://www.societyofrobots.com/member_tutorials/node/59
Both are line followers should be good info in them
http://www.societyofrobots.com/sensors_color.shtml
All the answers are here, you just gotta search first ;)
