Electronics => Electronics => Topic started by: benji on April 03, 2008, 02:30:45 AM
hello folks, i had this sharp ir sensor and im working now on interfacing it to my atmega.
the approach i want to do is to make a lookup table of voltages-destances
it goes this way
20 cm - 2.4 v
22 cm - 2.35v
24 cm - 2.23 v
150 cm - ????v
has anyone done such a thing before? if yes i would be glad to have all this readings cuz im having lots of problems finding them
(making perfect conditions for the sensor)
if there is any other approach wich is easier to make with the same preciesion i would be glad to hear about it
thanks ,,,,,
hey man i recently got this sharp Gp2D12 and i found out my digital readings using USART , i drew the graph using excel, found out the best straight trend line and also the equation, so i now have an equation which can give nearby values of digital readings for different angles , why dont u try that technic , this is how my graph loooks like
I dont know if the graph is kind of same for ur sharp ir as the distance measurement capacities are different..
(http://i303.photobucket.com/albums/nn135/superchiku/sharpir.jpg)
thanks for the picture
i guess the output voltage is not the same with my sensor,anyways why would i use uart?
just power the ir and read out by voltmeter ,,,,isnt this easier?
the question is how did you find the equation?based on how many readings?
thanks
well if u use uart then u get exact digital readings now using the multimeter means u get the voltage o/p which may not be as realiable and exact as usart , coz in usart i take 2 different readings at a distance and i take 10 distances alltogether so i get a graph which can tell me exactly how much my readings can vary for different distances
and abt the equation , its a facility available in ms excel which derives a nearby equation for the trendline i have set for the graph,although it is not 100% exact but still i can get 70-80 % accuracy with it which is sufficient for my purpose.
mmm i kind of seen a function in matlab that does the same thing, ill try using it.
anyways , how do you watch the values on the computer? hyper terminal?
well i use uart for that , i have written this code for atmega16 where the sensor input is in pin1 of porta
use the internal 8mhz oscillator and use this code , connect the serial port to the hyper terminal by using maz232 ic and ull get the readings..
# include<stdio.h>
# include<avr/io.h>
# include<util/delay.h>
# include<avr/interrupt.h>
# include<stdlib.h>
# include<string.h>
# include<avr/pgmspace.h>
#define USART_BAUDRATE 38400
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL)))- 1)
char u[11]="adcvalue\r\n";
char *d;
char b[10];
char *p;
unsigned int a;
void adcinitialize();
void uartinitialize();
void adcgetvalue();
void transferusart();
void printvalue(char *);
int main(void)
adcinitialize();
uartinitialize();
while(1)
adcgetvalue();
p=itoa(a,b,10);
strcat_P(b,PSTR("\r\n"));
d=&u[0];
transferusart();
return(0);
ADCSRA|=_BV(7)|_BV(ADPS2)|_BV(ADPS1);
ADMUX=0x60;
ADCSRA|=(1<<ADSC);
while(!(ADCSRA & (1<<ADIF)));
ADCSRA|=(1<<ADIF);
TCCR1B|=(1<<CS12);
UCSRB= (1<<RXEN) | (1<<TXEN);
UCSRC= (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1);
UBRRL=BAUD_PRESCALE;
UBRRH=(BAUD_PRESCALE>>8);
void adcgetvalue()
ADMUX=0x61;
ADCSRA|=(1<<ADSC);
ADCSRA|=(1<<ADIF);
a=ADCH;
while (*d != '\0')
while ((UCSRA & (1 << UDRE)) == 0) {}; // Do nothing until UDR is ready for more data to be written to it
UDR =*d ; // Echo back the received byte back to the computer
d++;
TCNT1=0;
while(TCNT1<=60000){};
TCNT1=0;
printvalue(p);
void printvalue(char *l)
while (*l != 0x00)
UDR =*l ; // Echo back the received byte back to the computer
l++;
TCNT1=0;
TCNT1=0;
i thought this is supposed to be high level programming much easier to understand and work with by us humans than machine code or even assembley
if this seems complicated , then imagine what assembly or machine lvl language code will look like
thanks man ill give it a shot
trust me the code will work also change ur fuse settings to
hfuse 0xd9
lfuse 0xd4
