Software => Software => Topic started by: hayama on April 11, 2008, 09:06:00 AM
Title: PID help for beginner
Post by: hayama on April 11, 2008, 09:06:00 AM
I need to implement a PID control. I've seen a lot of tutorials online, and I get the concept, but am just having thinking on how to implement it. For example I know the desired value vs. the actual value (is this from dead reckoning?) is needed. How is the desired value calculated? For example, the software tells the robot to move x inches forward. At the end of the process you would have the desired value and the actual value (encoder readings). However, what if your code is not to "move forward x inches", but rather just "move forward". How would the desired position be calculated then?
Also, what exactly is done with the output of the PID loop?
I appreciate the help.
Title: Re: PID help for beginner
Post by: benji on April 11, 2008, 10:03:12 AM
dont you say that youve answered your own question? ;)
there is no desired position in this case as you dont desire to go anywhere
make your questions a little more clear
Post by: Ro-Bot-X on April 11, 2008, 02:17:37 PM
I am no expert at PID as I am trying to understand how to use it myself. But here is what I understood:
- pid works by comparing the difference between the desired input with the current input and adjusts the output to reduce the difference
- the input may be speed and the output may be pwm for the motors
- to accelerate, the desired speed needs to be gradually increased by acceleration factor
- to slow down and stop at the desired distance, the desired speed needs to be gradually decreased by acceleration factor starting from a certain distance before the desired distance is reached
Post by: JesseWelling on April 11, 2008, 04:05:52 PM
This article is a very good reference for those wanting to see some code:
http://www.embedded.com/2000/0010/0010feat3.htm
Post by: stopgo on April 15, 2008, 10:54:03 AM
Hayama,
Benji's right, you have some logic errors.  Try to model the problem as something like this:
I want to go forward 15 clicks (on my wheel encoders), and I feed some variable v to my motors.
Then a really crude PID controller might go something like this
error = 0
while (get_clicks() != 15 clicks) {
  error += get_clicks() - 15
  v = Kp*(get_clicks() - 15) + Ki*error + Kd*(get_clicks() - previous_clicks)
  previous_clicks = get_clicks()
  update_motors(v)
Where you tune the K's yourself.
